TazzyB Posted August 25, 2019 Share Posted August 25, 2019 I have an SM124 monochrome monitor for my 1040 ST FM, and I really like the monochrome look of the CRT. I really want to just display something else on that monitor, other than the ST. Googling "VGA to Atari ST monitor port" just gave me results about adapters converting the monitor port to VGA, however I want it the other way around. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 25, 2019 Share Posted August 25, 2019 That was interesting some 25 years ago. Today not. Because you don't have monochrome mode with new video cards, or motherboards. I connected SM124 back in 1995 to some PC, with some God knows what video card, and it worked. But even then, it was not good, because resolution of 640x400 was too low already then. Now I don't see that you can set so low res at all, and mentioned lack of monochrome mode. Connecting anything other than some old PC seems not working - because of refresh rate, sync signals, progressive mode used ... Quote Link to comment Share on other sites More sharing options...
TazzyB Posted August 25, 2019 Author Share Posted August 25, 2019 (edited) 6 hours ago, ParanoidLittleMan said: That was interesting some 25 years ago. Today not. Because you don't have monochrome mode with new video cards, or motherboards. I connected SM124 back in 1995 to some PC, with some God knows what video card, and it worked. But even then, it was not good, because resolution of 640x400 was too low already then. Now I don't see that you can set so low res at all, and mentioned lack of monochrome mode. Connecting anything other than some old PC seems not working - because of refresh rate, sync signals, progressive mode used ... Ok. Thanks. So even if I found a way to connect it to a modern PC, it just wouldn't work at all? Edited August 25, 2019 by TazzyB Quote Link to comment Share on other sites More sharing options...
