doctor_x Posted September 14, 2019 Share Posted September 14, 2019 Greetings.. I am a collector of all things underground for the various 8 bit platforms - mainly wardialers, long distance code scanners, tone boxes, etc that were used back in the day (80's) by hackers and phreakers... There is a huge amount of this software for commodore, apple and even Atari and Tandy - but I've yet to stumble across anything written for the TI994a written for this purpose. Just figured I would throw a hook out and see if anyone recalls any software like this for the TI machine.. Maybe knows of a name that I could use to search by or at least add to the "wanted list", etc... If anyone cares to see my work (in progress for sure) you can do so at http://wardialers.org ... Thanks for any help .. 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 14, 2019 Share Posted September 14, 2019 Greetings.. I am a collector of all things underground for the various 8 bit platforms - mainly wardialers, long distance code scanners, tone boxes, etc that were used back in the day (80's) by hackers and phreakers... There is a huge amount of this software for commodore, apple and even Atari and Tandy - but I've yet to stumble across anything written for the TI994a written for this purpose. Just figured I would throw a hook out and see if anyone recalls any software like this for the TI machine.. Maybe knows of a name that I could use to search by or at least add to the "wanted list", etc... If anyone cares to see my work (in progress for sure) you can do so at http://wardialers.org ... Thanks for any help .. I had a wardialer at one time. I'll look on my old disks and see if it is still readableSent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
doctor_x Posted September 14, 2019 Author Share Posted September 14, 2019 10 minutes ago, arcadeshopper said: I had a wardialer at one time. I'll look on my old disks and see if it is still readable Sent from my LM-G820 using Tapatalk Thank you! Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted September 14, 2019 Share Posted September 14, 2019 I remember having a war dialer for my TI back the mid 80's, as a matter of fact it's how I found a few of the local BBS's, and other services like extra TELENET dial-in numbers. Now days though, I would never even contemplate using one. I gotta admit though, it was kind of cool coming back from work at the end of the day and having a list on the printer of every phone number in town that answered with a modem. 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted September 15, 2019 Share Posted September 15, 2019 Yes, there was a wardialer, commercial software. I do not remember the name however and I have not seen it in my remaining collection. Beery Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted September 15, 2019 Share Posted September 15, 2019 IIRC the version I used was written in TI Extended BASIC. The only reason I remember that is because I modified the output format for my printer. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 15, 2019 Share Posted September 15, 2019 100 REM PROGRAMMED BY MARK S LARRY FOR SCANNING BBS'S 110 REM PROGRAMMED 2/16/84, 120 ROW=5 130 RW=5 140 REM *********************145 REM********************* 150 REM INITIALIZE SCREEN, TEXT COLORS AND DISPLAY MENU 160 CALL SCREEN(5) 170 FOR CHECK=0 TO 14 :: CALL COLOR(CHECK,16,5) :: NEXT CHECK :: DISPLAY AT(2,7)ERASE ALL BEEP:"Menu Selection" 180 DISPLAY AT(ROW,4):"1 Auto dialer" :: DISPLAY AT(ROW+2,4):"2 Display results" :: DISPLAY AT(ROW+4,4) 190 DISPLAY AT(ROW+6,4):"3 Terminate" :: DISPLAY AT(ROW+8,4):"Selection 3" :: ACCEPT AT(ROW+8,14)SIZE(-1)BEEPVALIDATE("123"):SELECT 200 IF SELECT=1 THEN 340 :: IF SELECT=2 THEN 230 ELSE RUN "DSK1.LOAD" 210 REM ********************* 220 REM DISPLAY RESULTS OF SEARCH 230 CALL CLEAR :: CALL SCREEN(5) :: OPEN #10:"DSK1.WARGAME",INPUT,VARIABLE 60 240 DISPLAY AT(2,2):"Phone numbers with carrier tones." 250 INPUT #10:S 260 DISPLAY AT(RW,8):S 270 RW=RW+1 280 REM 290 IF RW>18 THEN DISPLAY AT(20,2):"Depress any key to continue." :: CALL KEY(0,J,K) :: IF K=0 THEN 280 ELSE CALL CLEAR :: RW=5 300 IF EOF(10)=1 THEN CLOSE #10 ELSE 240 310 DISPLAY AT(20,2)BEEP:"*** Operation Complete ***" :: FOR ZE=1 TO 1000 :: NEXT ZE :: CALL CLEAR :: RW=5 :: GOTO 170 320 REM ******************** 330 REM USER ENTERS PHONE NUBERS TO DIAL 340 OPEN #10:"DSK1.WARGAME",APPEND,VARIABLE 60 350 F=5 :: CALL CLEAR :: CALL SCREEN(5) 360 OPEN #1:"RS232",DISPLAY,UPDATE,VARIABLE 255 :: PRINT #1:"AT S7=19 C0" :: CLOSE #1 370 DISPLAY AT(1,1):"To search for carrier tones, enter starting and ending phone numbers." 380 DISPLAY AT(6,2):"ENTER START NUMBER " 390 ACCEPT AT(8,9)BEEPVALIDATE(DIGIT):B 400 DISPLAY AT(12,2):"ENTER END NUMBER" 410 ACCEPT AT(14,9)BEEPVALIDATE(DIGIT):C 420 REM ********************* 430 REM CHECK IF FORWARD DIALING 440 IF B=C THEN 510 :: IF C>B THEN 510 450 DISPLAY AT(7,3)BEEP:"Forward Dialing Only" :: FOR DELAY=1 TO 600 :: NEXT DELAY :: CALL CLEAR :: GOTO 350 460 REM ********************* 470 REM 480 REM 490 REM ******************** 500 REM DIALS PHONE NUMBER ENTERED BY USER. 510 CALL CLEAR 520 ON ERROR 1000 530 OPEN #1:"RS232",DISPLAY,UPDATE,VARIABLE 255 540 GOTO 560 550 IF B>C THEN CLOSE #10 :: PRINT #1:"AT C1" :: CLOSE #1 560 DISPLAY AT(2,1)BEEP:"Dialing sequence operating" 570 PRINT #1:"AT DT"&STR$(B) 580 DISPLAY AT(F,2):B 590 FOR Z=1 TO 100 600 NEXT Z 610 REM ******************** 620 REM CHECKS STATUS OF CALLS 630 LINPUT #1:A$ 640 LINPUT #1:B$ 650 F=F+1 660 REM ********************* 670 A$=CHR$(10)&"CONNECT" :: IF B$=A$ THEN 760 ELSE 680 680 A$=CHR$(10)&"NO CARRIER" :: IF B$="NO CARRIER" OR B$=A$ THEN 690 690 REM ******************* 700 REM 710 REM 720 REM 730 REM DISPLAYS STATUS OF CALLS 740 DISPLAY AT(F-1,13):B$ 750 GOTO 810 760 DISPLAY AT(F-1,13):B$ 770 PRINT #10:B 780 CLOSE #1 790 GOTO 860 800 REM *********************546 REM TIMING LOOP FOR "NO CARRIER" 810 FOR SE=1 TO 100 :: NEXT SE :: CLOSE #1 :: CALL KEY(0,K,S) :: IF K=32 THEN CLOSE #10 :: GOTO 120 ELSE GOTO 890 820 REM ********************/556 REM 830 REM 840 REM ********************* 850 REM TIMING LOOP FOR "CONNECTED" 860 FOR SE=1 TO 8000 870 NEXT SE 880 REM ******************** 890 OPEN #1:"RS232",DISPLAY,UPDATE,VARIABLE 255 900 B=B+1 910 IF B>C THEN PRINT #1:"AT C1" :: CLOSE #10 :: CLOSE #1 :: GOTO 120 920 ON ERROR 1010 930 FOR GE=1 TO 200 :: NEXT GE 940 IF F>18 THEN CALL CLEAR :: F=5 :: GOTO 560 950 PRINT #1:"AT DT"&STR$(B) 960 GOTO 580 970 STOP 980 REM ******************** 990 REM ERROR CODES 1000 CALL ERR(W,X,Y,Z) :: GOTO 630 1010 CALL ERR(W,X,Y,Z) :: GOTO 630 1020 REM ******************** 3 Quote Link to comment Share on other sites More sharing options...
wierd_w Posted September 15, 2019 Share Posted September 15, 2019 these days you would hit more fax machines than you would bbs modems. Interesting to see how they used the AT command set return values to determine if a carrier picked up though. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted September 16, 2019 Share Posted September 16, 2019 This dsk has quite a few phreakin' programs and text files SMRT_UTILS.DSK 4 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted September 16, 2019 Share Posted September 16, 2019 Hi, I'm looking for: TEXAS TELEPHONES(S). Home Computing Weekly Magazine Issue 049. But I don't care to type it in! Quote Link to comment Share on other sites More sharing options...
+9640News Posted September 16, 2019 Share Posted September 16, 2019 Seems like Micropendium had an advertisement. Would have been in the mid 80’s. Quote Link to comment Share on other sites More sharing options...
S1500 Posted September 19, 2019 Share Posted September 19, 2019 This is fascinating. I didn't use wardialers(Tone Loc) until I had a DOS system. With that being said, any guidance on that TI SMRT_UTILS.DSK? I'm not having much luck getting anything to run. My E/A skills are a bit rusty. Which file's the wardialer program? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted September 19, 2019 Share Posted September 19, 2019 I had a little luck on Classic99 using RXB 2012. I loaded the disk in drive1... OLD DSK1.LOAD/SU When I tried option 4 Classic99 disappeared. 1 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted September 19, 2019 Share Posted September 19, 2019 13 hours ago, HOME AUTOMATION said: When I tried option 4 Classic99 disappeared. Hmm.. it worked here. Are you on the latest? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted September 20, 2019 Share Posted September 20, 2019 15 hours ago, Tursi said: Hmm.. it worked here. Are you on the latest? I was using QI372. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 20, 2019 Share Posted September 20, 2019 First off classic99 has no rs232You should use Fred Kaals emu as it does support rs232 Sent from my LM-G820 using Tapatalk Quote Link to comment Share on other sites More sharing options...
doctor_x Posted November 5, 2019 Author Share Posted November 5, 2019 old thread - but I don't think anything on that disk is a wardialer. "disassembler" just sounds like a program disassembler... Quote Link to comment Share on other sites More sharing options...
+9640News Posted November 6, 2019 Share Posted November 6, 2019 There is a War Dialer out there somewhere as I used to have a copy, as well as Micropendium advertised one back in the 80's. Beery Quote Link to comment Share on other sites More sharing options...
