Lillapojkenpåön Posted September 21, 2019 Share Posted September 21, 2019 (edited) I looked into C/C++ a couple days ago and realized how similar it was to bB, I know I'm not the only one who only knows bB so I thought I would share my findings since I found it very inspiring, especially considering SpiceC. I will make different posts with commonly used bB code and it's equivalent in C/C++ and have an index to them here in the first post, and hopefully people chime in with their knowledge, corrections or questions. Spoiler Online C++ compiler: https://www.tutorialspoint.com/compile_cpp_online.php Example to compile: #include <iostream> using namespace std; int main() { int _PlayerY[9]; int _LoopCounter; const int _Y_POS[9] = {10, 20, 30, 40, 50, 60, 70, 80, 90}; #define forloop(x) for (_LoopCounter = 0; _LoopCounter < (x); _LoopCounter++) forloop(9) { _PlayerY[_LoopCounter] = _Y_POS[_LoopCounter]; cout << _PlayerY[_LoopCounter] << endl; } return 0; } Edited September 26, 2019 by Lillapojkenpåön 1 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) Integer variables bB Dim _Aristocrat = a Dim _Bangladesh = b Dim _Cola = c Dim _Didrick = d _Aristocrat = 0: _Bangladesh = 0: _Cola = 0: _Didrick = 0 if _Aristocrat > _Bangladesh then _Cola = 25: _Didrick = 1 else _Cola = 50: _Didrick = 0 bB Comparison Operators: rem = equal to rem <> not equal rem > greater than rem < less than rem >= greater than or equal to rem <= less than or equal to bB Logical Operators: rem && AND rem || OR rem ! NOT Integer variables C/C++ int _Aristocrat; int _Bangladesh; int _Cola; int _Didrick; _Aristocrat = 0; _Bangladesh = 0; _Cola = 0; _Didrick = 0; if (_Aristocrat > _Bangladesh) {_Cola = 25; _Didrick = 1;} else {_Cola = 50; _Didrick = 0;} C/C++ Comparison Operators: // == equal to // != not equal // > greater than // < less than // >= greater than or equal to // <= less than or equal to C/C++ Logical Operators: // && AND // || OR // ! NOT Spoiler As you can see they are very similar, but C/C++ is usually written like this: if (_Aristocrat > _Bangladesh) { _Cola = 25; _Didrick = 1; } else { _Cola = 50; _Didrick = 0; } The compiler ignores whitespace so you can write it anyway you want. //================================================ Give one variable many aliases: int _Aristocrat; int * const _Bangladesh = &_Aristocrat; int * const _Cola = &_Aristocrat; int * const _Didrick = &_Aristocrat; The three nicknames can not be made to point to anything else, the compiler will not generate additional code to handle _Aristocrat or *_Bangladesh, neither reserve space for a pointer. Edited September 26, 2019 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) Boolean bB def _Aristocrat=a{0} def _Bangladesh=a{1} def _Cola=a{2} def _Didrick=a{3} _Aristocrat=0 _Bangladesh=0 _Cola=1 _Didrick=1 if _Aristocrat && !_Bangladesh then _Cola = 1: _Didrick = 0 if !_Aristocrat && _Bangladesh then _Cola = 0: _Didrick = 1 Boolean C/C++ bool _Aristocrat = false; bool _Bangladesh = false; bool _Cola = true; bool _Didrick = true; if (_Aristocrat && !_Bangladesh) {_Cola = true; _Didrick = false;} if (!_Aristocrat && _Bangladesh) {_Cola = false; _Didrick = true;} Spoiler Short Hand If...Else (Ternary Operator) If you have only one statement to execute for if, and one for else, use this. Syntax: variable = (condition) ? expressionTrue : expressionFalse; _Cola = (_Bangladesh) ? true : false; same as: if (Bangladesh) {_Cola = true;} else {_Cola = false} //=========================================== Those examples uses an entire variable as one boolean, here's one way of using the different bits. //create the variable unsigned char flags = 0; //and some masks const unsigned char _Aristocrat { 1 << 0 }; // 0000 0001 const unsigned char _Bangladesh { 1 << 1 }; // 0000 0010 const unsigned char _Cola { 1 << 2 }; // 0000 0100 const unsigned char _Didrick { 1 << 3 }; // 0000 1000 const unsigned char mask4 { 1 << 4 }; // 0001 0000 const unsigned char mask5 { 1 << 5 }; // 0010 0000 const unsigned char mask6 { 1 << 6 }; // 0100 0000 const unsigned char mask7 { 1 << 7 }; // 1000 0000 //Bitwise OR: flags |= _Aristocrat; // turn on bit 0 flags |= (_Aristocrat | _Bangladesh); // turn bits 0 and 1 on at the same time //Bitwise AND and Bitwise NOT together: flags &= ~_Aristocrat; // turn off bit 0 flags &= ~(_Aristocrat | _Bangladesh); // turn bits 0 and 1 off at the same time //Bitwise XOR: flags ^= _Aristocrat; // flip bit 0 flags ^= (_Aristocrat | _Bangladesh); // flip bits 0 and 1 at the same time (flags & _Bangladesh) ? flags |= _Cola : flags &= ~_Cola; same as: if (flags & _Bangladesh) {flags |= _Cola;} else {flags &= ~_Cola;} Hard for me to see what it does so I use aliases: #define ON |= #define OFF &= ~ #define FLIP ^= Edited September 25, 2019 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) For Loop bB dim _LoopCounter = temp5 for _LoopCounter = 0 to 9 player1y[_LoopCounter] = _Y_POS[_LoopCounter] next rem put outside of code data _Y_POS 10, 20, 30, 40, 50, 60, 70, 80, 90 end Spoiler Same as: _LoopCounter = 0 __loop player1y[_LoopCounter] = _Y_POS[_LoopCounter] ; player1y = 10 first, player2y = 20 first loop, ; player3y = 30 second loop etc. _LoopCounter = _LoopCounter + 1 if _LoopCounter < 9 then goto __loop For Loop C/C++ int _PlayerY[9]; // Create an array of nine integers int _LoopCounter; const int _Y_POS[9] = {10, 20, 30, 40, 50, 60, 70, 80, 90}; // Read-Only array, same as a data table in bB for (_LoopCounter = 0; _LoopCounter < 9; _LoopCounter++) { _PlayerY[_LoopCounter] = _Y_POS[_LoopCounter]; } Spoiler for (statement 1; statement 2; statement 3) { // code block to be executed } //Statement 1 is executed (one time) before the execution of the code block. //Statement 2 defines the condition for executing the code block. //Statement 3 is executed (every time) after the code block has been executed. Same as: _LoopCounter = 0; //Statement 1 __loop: _PlayerY[_LoopCounter] = _Y_POS[_LoopCounter]; // player1y = 10 first, player2y = 20 first loop, // player3y = 30 second loop etc. _LoopCounter++; //Statement 3 if (_LoopCounter < 9) {goto __loop;} //Statement 2 //===================================================== If you don't want to write so much, you can create preprocessor macros: #define forloop(x) for (int _LoopCounter = 0; _LoopCounter < (x); _LoopCounter++) // the x will be replaced by what ever is put into the parenthesis forloop(9) { _PlayerY[_LoopCounter] = _Y_POS[_LoopCounter]; } Edited September 26, 2019 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted September 21, 2019 Author Share Posted September 21, 2019 on...goto bB dim _Counter = a on _Counter goto __case_1 __case_2 __case_3 __case_4 __case_5 __case_6 __case_7 goto __break ; if _Counter > 6 __case_1 rem code block goto __break __case_2 rem code block goto __break __case_3 rem code block goto __break __case_4 rem code block goto __break __case_5 rem code block goto __break __case_6 rem code block goto __break __case_7 rem code block __break switch C/C++ int _Counter; switch (_Counter) { case 1: // code block break; case 2: // code block break; case 3: // code block break; case 4: // code block break; case 5: // code block break; case 6: // code block break; case 7: // code block break; } Spoiler Note that in bB you will jump to case 1 when the counter is 0, and case 7 when it's 6, in C/C++ the numbers correspond. Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted September 23, 2019 Author Share Posted September 23, 2019 (edited) gosub bB gosub __MySubroutine ; jumps to MySoubroutine rem put outside of code __MySubroutine rem code block return Spoiler temp1 = player1x : temp2 = player1y ; send copies to the subroutine gosub __MySubroutine player1x = temp1 : player1y = temp2 ; store back the returned result __MySubroutine ; do alot of boundary checking with temp1 and temp2 ; that determines where the player go next and "move" temp1 and temp2 there return ; now the code is re-usable because you just pass copies to the subroutine in separate variables, ; you could pass copies of player 2's position, or player 3's etc. That would be very similar to "passing parameters by values" to functions. temp1 = 4 gosub __MySubroutine __MySubroutine ; if player1x[temp1]...then player1x[temp1]... ; if player1y[temp1]...then player1y[temp1]... ; if player1height[temp1]...then player1height[temp1]... ; if _NUZIZ1[temp1]...then _NUZIZ1[temp1]... return ; passing 4 as index would check and change player5x, y, height and nusiz ; passing 0 as index would check and change player1x, y, height and nusiz That would be very similar to "passing parameters by reference" to functions. function C/C++ void MyFunction(); // function prototype, needed for the compiler if you want to put the function below where it's being called from // you could put the function here and remove the prototype // we jump from the main function to MyFunction // variables are only locally known to the function they are defined in // to create a global variable that can be accessed by any function define it here outside of any function int main() { MyFunction(); // jumps to MyFunction } void MyFunction() // function declaration { //code block } Spoiler "passing parameters by values" int main() { player5x = MyFunction(player5x); // stores a copy of the value of player5x in function variable temp1 } int MyFunction(int temp1) //int means we will return a value in the form of an integer { //do lots of horisontal boundary checking with temp1 //that determines where the player go next and "move" temp1 return temp1; //return the value to player5x } "passing parameters by reference" int main() { MyFunction(player5x, player5y); // stores a reference to player5x in function variable temp1 // stores a reference to player5y in function variable temp2 } void MyFunction(int& temp1, int& temp2) // void means we won't return a value { //using temp1 and temp2 in the function will now be the same as using player5x and player5y } Edited September 23, 2019 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
