Flags with Read/Write-only variables
Karl G
In the case of on-cart RAM with separate read and write addresses, if I write to one of these variables, do the appropriate flags still get set based on the changed value of the variable? E.g. if I decrement a write variable, will it still trigger the zero flag when that variable becomes zero?
Edit: now I'm wondering if INC or DEC would even work on these variables, since I assume it does both a read and a write "under the hood".
The flags should be set appropriately, but the write back will not work as it is writing back to the read address. So you really have to do INC and DEC a longer way using this ram. I usually just load the value into the X, do a DEX, and write back.
There's more on instruction timings cycle by cycle here:
http://nesdev.com/6502_cpu.txt
If you take DEC absolute for example, it does this:
     Read-Modify-Write instructions (ASL, LSR, ROL, ROR, INC, DEC,
                                     SLO, SRE, RLA, RRA, ISB, DCP)
        #  address R/W description
        1    PC     R  fetch opcode, increment PC
        2    PC     R  fetch low byte of address, increment PC
        3    PC     R  fetch high byte of address, increment PC
        4  address  R  read from effective address
        5  address  W  write the value back to effective address,
                       and do the operation on it
        6  address  W  write the new value to effective address
The effective address in this case is the one it reads from. So it tries to write back to the read address, and that won't work in this case.
  • Thanks 2
