+Andrew Davie Posted August 6, 2020 Author Share Posted August 6, 2020 This one has come up a treat. I like it a lot. The colours, in particular, seem to work well together. There's a small gap between the squares, and that allows me to get the edges a bit crisper by printing the blue base layers first. More colour swaps when printing, but I've got that down to a fine art now. i'm going to round those square edges, and put a hinge part on that side as well... and some sort of fricton-based closing clamps. Then it will be close to completion and I might feel like some programming again. On the inside, I plan to put stick-backed felt in the flat bits to (a) protect the cart/pieces, but also (b) hide the see-through-ness. 4 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted August 6, 2020 Share Posted August 6, 2020 1 hour ago, Andrew Davie said: I like the colors. Do you plan to print them all by yourself, or are you planning to use a 3d printing service like craftcloud3d ? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 6, 2020 Author Share Posted August 6, 2020 Just now, Al_Nafuur said: I like the colors. Do you plan to print them all by yourself, or are you planning to use a 3d printing service like craftcloud3d ? TY. I'll print them myself. The idea is to do a small run where I have done as much as possible myself, so it's effectively "hand crafted" by the author. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 6, 2020 Author Share Posted August 6, 2020 Very frustrating having to wait till the next day to do a test print. I don't trust my printer enough to run it overnight - visions of it bursting into flames and all that means that I pretty much have to be nearby (and awake) when it's printing. So, here's a video of the model - it's getting close to final now. I've added some hinges to the spine - these will allow it to open flat, hopefully. Hinges aren't shown - they're basically formed with an oval with a hole each foci. The hole just big enough to slide some 1.75mm filament through. So, you can see that hole in the video - I'll put in the hinges and hold them with a long segment of filament through the hole. boxhinge.mp4 I've rounded the edges of the box itself. Looks nice to me. I've added two magnet inserts on the corners - room for a 6mm x 6mm magnet. Will order these. I expect neodymium magnets will be more than strong enough to keep the box closed. I've added a small "thumb slot" to aid with opening the box - but really more just a style thing. That's about it. Will print it tomorrow. 2 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 6, 2020 Author Share Posted August 6, 2020 2 hours ago, Andrew Davie said: TY. I'll print them myself. The idea is to do a small run where I have done as much as possible myself, so it's effectively "hand crafted" by the author. I guess I may as well print the cartridge shells myself, too. I'll have to do a design for that, too, I guess. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 7, 2020 Author Share Posted August 7, 2020 (edited) That last iteration printed OK. I haven't scraped off all the various strings etc., but it's good enough to show. There are a few things I'm going to change but for now I was able to put it alongside the previous iteration so I could see what a "full board" would look like. Pretty good. In this iteration I re-added the surrounding border, but the biggest change is the gold chesspieces on the side of the board. At first I wasn't terribly happy with the result, but on reflection these don't look half-bad. I'm going to reduce them to just 6 or maybe 4 pieces. And on the other half of the box, not sure what I'll have yet - maybe an ident of the game. The two halves fit nicely (vertically) inside a standard '2600 box, so that's good. I may reduce layer size just a fraction to give the cartridge just a little more room. In all, it's extremely tight packing to expect a box to hold a cart, pieces, and a folding-out chessboard, but I think this will end up workable. There's a bit of an offset in the pic (inside the box) because the two halves are different designs and internally hold the cart (which IS inside) slightly different positions. That won't happen when I'm using two of the same parts. This one took me about 6 hours to print, so it's very slow going and I haven't yet done two of the same (which would give me a completed print). The hole for the 'hinge' didn't come out large enough, and I've thought of a different ("invisible" way to mount the magnets in the corner, so I'll be changing those things at the very least. I may make the spine for the hinge area a bit larger, the walls on the cart cradle a bit thicker. It all depends now on what chess pieces I use, and if they're going to fit. Well, I guess they *have to*. So, perhaps time to buy my favourite(s) and see how they go. Will take about 6 weeks to arrive, at a guess. These are all being printed with a very low-cost printer using an 0.4mm nozzle, and just a single colour at a time. I'm "hot-swapping" filament during prints to achieve the multiple colours shown. I do this by splitting prints into multiple parts and printing all of one colour at a time. It's not terribly difficult, but you do need to have your technique down solid to get good results. Edited August 7, 2020 by Andrew Davie 8 Quote Link to comment Share on other sites More sharing options...
alex_79 Posted August 8, 2020 Share Posted August 8, 2020 23 hours ago, Andrew Davie said: In all, it's extremely tight packing to expect a box to hold a cart, pieces, and a folding-out chessboard, but I think this will end up workable. II you're going to print the cart shells too, you could probably make it shorter than the standard atari ones (depending on the size of the PCB you're going to use). 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 9 minutes ago, alex_79 said: II you're going to print the cart shells too, you could probably make it shorter than the standard atari ones (depending on the size of the PCB you're going to use). Good point. The purists might be up in arms. I need to find a good starting point for shell form/design. 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted August 8, 2020 Share Posted August 8, 2020 1 hour ago, Andrew Davie said: Good point. The purists might be up in arms. I need to find a good starting point for shell form/design. There is a design at Thingiverse: https://www.thingiverse.com/thing:1790785 AtariAge User @SvOlli has modified it to fit the UnoCart. 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 1 minute ago, Al_Nafuur said: There is a design at Thingiverse: https://www.thingiverse.com/thing:1790785 AtariAge User @SvOlli has modified it to fit the UnoCart. Thanks; it's the modified design I'd really like to find! Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted August 8, 2020 Share Posted August 8, 2020 18 minutes ago, Andrew Davie said: Thanks; it's the modified design I'd really like to find! I don't know if he has made it publicly available, maybe you should just ask him via PM Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 6 minutes ago, Al_Nafuur said: I don't know if he has made it publicly available, maybe you should just ask him via PM ... or get off my lazy bum and do my own! 3 Quote Link to comment Share on other sites More sharing options...
alex_79 Posted August 8, 2020 Share Posted August 8, 2020 Thinking more about it, the cartridge slot on 6 switch consoles is about 4 cm deep (the slot is less recessed on 4-switch and juniors models). So, apart for that area, you can get creative with the design of the top of the cartridge. For example, it could be shaped like a chess piece... Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 1 hour ago, alex_79 said: Thinking more about it, the cartridge slot on 6 switch consoles is about 4 cm deep (the slot is less recessed on 4-switch and juniors models). So, apart for that area, you can get creative with the design of the top of the cartridge. For example, it could be shaped like a chess piece... Yes, great idea. A king comes to mind - that would be an awesome cartridge. 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 (edited) Choosing a name for a game/program is, I'm sure everyone will agree, the hardest but most important part of all. It's real "hard work", so to speak. So, I had a candidate in mind -- "chessticle", but alas that one is taken. I want it to be a bit of a pun, but obvious it's a chess program, too. I also want a name aligned with the basic premise/approach of this particular implementation. That is, speaking, agressive/rude, inappropriate. So here are some candidates... * grouchess * speechess * bitchess * debouchess * bellyachess I also briefly considered naming it "Andrew Davie" just to throw a spanner in the works. Edited August 8, 2020 by Andrew Davie Quote Link to comment Share on other sites More sharing options...
+Karl G Posted August 8, 2020 Share Posted August 8, 2020 Bitchess? I think that works on a couple of levels. 1 1 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 8 minutes ago, Karl G said: Bitchess? I think that works on a couple of levels. Totally agree. 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 8, 2020 Share Posted August 8, 2020 Maybe add a tweak to the capitalisation, so the chess part doesn't get lost? i.e. BitChess or BITChess Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 8, 2020 Author Share Posted August 8, 2020 It could startup and say "welcome, bitchess" 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted August 8, 2020 Share Posted August 8, 2020 Bitchess for the win. Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted August 8, 2020 Share Posted August 8, 2020 (edited) 1 hour ago, Andrew Davie said: * bitchess ? ? Edited August 8, 2020 by Al_Nafuur Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 8, 2020 Share Posted August 8, 2020 1 hour ago, Andrew Davie said: It could startup and say "welcome, bitchess" Not my kind of humor. 2 Quote Link to comment Share on other sites More sharing options...
+D Train Posted August 9, 2020 Share Posted August 9, 2020 Rude Chess? Angry Chess? Andrew Davie's Angry Chess? that scans well, at least... Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted August 9, 2020 Share Posted August 9, 2020 (edited) "Andrew Davie's Bitchess" ? I'm not sure my wife will allow me to order this Edited August 9, 2020 by Al_Nafuur Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted August 9, 2020 Author Share Posted August 9, 2020 The suggestion to name it "Andrew Davie" was not to name it something like "Andrew Davie's Chess", but to actually call it "Andrew Davie". As in, I think I'll have a game of "Andrew Davie" Quote Link to comment Share on other sites More sharing options...
