Goochman Posted January 18, 2020 Share Posted January 18, 2020 I bought one of those NE2000 cart port network cards many moons ago. Every time I try to use it I seem to run into a mysterious problem that takes days to fix. For the most part Im pretty sure Ive got the right drivers and control panel (v1.31) - I think it comes down to my route table for me trying to connect to a machine on my local network. My network is 192.168.1.x My Gateway is 192.168.1.1 The hard wired IP address for STiNG is 192.168.1.58 which appears open from what I can tell on my network I believe the ROUTE.TAB is my issue as if I have things somewhat right the ACTIVE light will flash on the card when I ping. If I make a mistake it seems the ACTIVE light wont flash. Any thoughts on the right way to configure this? Here is the ROUTE.TAB file and what I thought was right but obviously isnt. # Format of routes comprises four entries, separated by TABs : # - First the network (subnet number) which can be reached by using this # route. # - Next the subnet mask associated with that network. # - Then the port name follows. This is the name as listed by ConfSTinG or # STNGPORT.CPX. # - Last entry is the IP address of a host on the attached network that # can act as a gateway. # # The network specified can be directly attached to the specified port, in # that case no gateway is needed, as the datagram can be routed directly. # For a route to a network that is directly attached therefore the gateway # entry should be set to 0.0.0.0. # # For an attached Ethernet the gateway entry specifies the gateway out of # the Ethernet, for a serial line it is simply the host at the other end. # # It is advisable to finish the table by a default route. This route is most # easily obtained by specifying a network 0.0.0.0 with a netmask 0.0.0.0. # # Routes with invalid addresses or absent ports are ignored. # # 192.68.0.0 255.255.255.240 Modem 1 192.68.0.1 # 130.75.75.0 255.255.255.128 Ser.2/LAN 0.0.0.0 # 0.0.0.0 0.0.0.0 Ser.2/LAN 130.75.75.16 # 192.168.1.0 255.255.255.0 EtherNet 192.168.1.1 0.0.0.0 0.0.0.0 EtherNet 0.0.0.0 Ive also tried 0.0.0.0 0.0.0.0 EtherNet 192.168.1.1 Quote Link to comment Share on other sites More sharing options...
