DPC+ bB player0 graphics in other banks
SpiceWare
NOTE: There's a bug in this version, get the latest version in Reply 6
Stationary graphics are defined as normal.  The other 4 images are defined using data statements in various banks.
700978832_ScreenShot2020-01-26at5_03_19PM.thumb.png.8643ae3472ca9049f645d446fa7cc8ad.png
Stationary
Moving up
Moving down
Moving left
Moving right
graphics_bank_test.zip
3 hours ago, SpiceWare said:
I was just scanning the entire site looking for what the usual ((>WALK) & $0f) | (((>WALK) / 2) & $70) does, I guess it just points to the graphics bank? does dasm allways assume it's in the first bank or why do you have to add this manually?
Could you walk me through what the & $0f does so I can learn something today? ?
Does it just turn of half the byte to make sure it's 0000 before adding the bank number????
Edited by Lillapojkenpåön
Hmm - didn't notice that bB was RORG'ing each bank to have a different upper nybble, that makes things easier as you don't have to manually keep track of the bank to add.
  • player_up = $5088 - bank 3, needed to add $20
  • player_down = $5091
  • player_left = $7088 - bank 4, needed to add $30
  • player_right = $9088 - bank 5, needed to add $40
  • color_up = $b088 - bank 6, needed to add $50
  • color_down = $b093
The way that works is:
  1. lda #(>player_up & $0f) | ((>player_up / 2) & $70)
  2. lda #(>$5088 & $0f) | ((>$5088 / 2) & $70)
  3. lda #($50 & $0f) | (($50 / 2) & $70)
  4. lda #($00) | ($28 & $70)
  5. lda #($00) | ($20)
  6. lda #$20
  1. lda #(>player_left & $0f) | ((>player_left / 2) & $70)
  2. lda #(>$7088 & $0f) | ((>$7088 / 2) & $70)
  3. lda #($70 & $0f) | (($70 / 2) & $70)
  4. lda #($00) | ($38 & $70)
  5. lda #($00) | ($30)
  6. lda #$30
I also had the >( in the wrong order, should have been (>. It didn't cause a problem with graphics in the first 256 bytes of the bank, but would have as soon as the 2nd nybble was anything other than 0 - for example if player_up was at $5487, this would have happened:
  1. lda #>(player_up & $0f) + $20
  2. lda #>($5487 & $0f) | + $20
  3. lda #>($0007) + $20
  4. lda #($00) + $20
  5. lda #$20
but this is what we really need to happen:
  2. lda #(>$5487 & $0f) | ((>$5487 / 2) & $70)
  3. lda #($54 & $0f) | (($50 / 2) & $70)
  4. lda #($04) | ($28 & $70)
  5. lda #($04) | ($20)
  6. lda #$24
I've revised it again so you can now move the data statements around and not have to worry about which bank they end up in.
graphics_bank_test 4.zip
I tried to point the colors to RAM awhile ago like this
 asm
    lda #<STACKbegin
    sta player0color
    lda #(>STACKbegin) & $0F
    sta player0color+1
end
so I could just push colors to the stack
but in main the flashdata adress I guess keeps you from pointing anywhere else, do you know if it would be possible to change that line to allow or just exclusively be able to point to first of all RIOT RAM since it's fast to read and write to, or the stack or worst case copy from the not visable part of the color queue up to the visable part?
            flashdata+(RIOT[player0color+1]<<8)+RIOT[player0color],   //source
            queue+(fetcheraddr[46]<<8)+fetcheraddr[38],    //destination
Just a small update, so i have somewhat broken down the test program and realized the hi and lo player0 pointers don't need to be in the mainloop. As long as they're initiated at the start of the program, there is no need to keep updating within the mainloop other then when required by the asm code @SpiceWare provided.
here's the bas and bin
graphics_data_test.bas
graphics_data_test.bin
Edited by TwentySixHundred
Typo
Broken down further more i have removed the asm sub-routine from the mainloop. I feel for optimization of the mainloop it's important to remove any code when possible. Especially if this data is not needed to be called every frame and depending on the game concept ect. Having the asm sub-routine separate, feels to me like a function to call rather then bB code. It's a personal preference of program flow and structure, sort of like a mini kernel from my perspective. Anyway see below
Actually now my brain is ticking about optimization, with my last example adding the goto command is most likely slower but rather cleans up structure the mainloop if that's your style. I will add by using this method it's most likely slower as you're fetching the graphics data from ROM rather then RAM. From my understanding of what @SpiceWare was explaining about the DPC+/ARM and BUS Stuffing is that graphics data is preloaded into RAM.
However with that in mind, i would say having the goto command fetch the sprite data from the same bank as your mainloop would be alot faster then bankswitching. Provided that's where you wanted to store the data and depending on when the data is fetched. So for instance, with a game like Stay Frosty if you wanted to update the player sprite when collecting the ice cubes it wouldn't be all that noticeable when bankswitching. Although a game that updates the sprite data frequently id say having that data stored with the same bank would be the faster option if desired.
I'm not a 100% sure and maybe @SpiceWare could chime in sometime to clarify that statement.
They are still as much in the mainloop as Darrell's example, you're just visually jumping to somewhere else which doesn't optimize but rather adds unnecessary jumps, if you mean the sprite that you moved to the init, it does nothing in your code other than set the playerheight to eight, it points to a sprite and color but is immediately overridden on the first frame when the pointers are set to something else in NOTFIRE. Darrell had it in the mainloop because it was the stand still sprite, so just a easy way to reset to that one when no joystick direction is pressed.
You can set the high pointers in the init tho if you merge the graphics and colors
You were never pointing to RAM only ROM, and you're not bankswitching when seting the pointers in one bank to a table in another, you're just storing a number to a variable so the speed is the same.
You also weren't using the last code Darrell posted, that let's you put the graphics in any bank without changing any numbers.
graphics_data_test2.bas
Yes i was aware later that adding the goto command was basically just moving the code outside the mainloop rather then optimizing. I think because i changed the standing sprite to a continuously moving sprite the hi lo pointers i hadn't noticed it was needed for the standing sprite.
Also thanks for clarifying that no matter what bank the data is stored in, it's not actually bankswitching. I was under the assumption you would need to in order to access that data from the bank. All good ?
I figured out how to do this by looking in the default.bas.asm file to see what it was doing.  For the color it did this:
.L032 ;  player0color:
	LDX #<playercolorL032_0
	STX player0color
	LDA #((>playercolorL032_0) & $0f) | (((>playercolorL032_0) / 2) & $70)
	STA player0color+1
for the graphics it did this:
.L031 ;  player0:
	LDX #<playerL031_0
	STX player0pointerlo
	LDA #((>playerL031_0) & $0f) | (((>playerL031_0) / 2) & $70)
	STA player0pointerhi
	LDA #8
	STA player0height
The DPC+ bB routines use some ARM/C code that you can find in bB/includes/custom/main.c:
  // fill color from player0, wrapping if necessary...
  //my_memcpy(queue+(dfhigh(0)<<8)+dflow(0),
  my_memcpy(queue+get32bitdf(0),
            flashdata+(RIOT[player0color+1]<<8)+RIOT[player0color], RIOT[player0y],
            RIOT[player0height]);
  //my_memcpy(queue+(dfhigh(2)<<8)+dflow(2),
  my_memcpy(queue+get32bitdf(2),
            flashdata+(RIOT[player0pointerhi]<<8)+RIOT[player0pointerlo], 0,
queue = Display Data RAM
flashdata = ROM
RIOT = 6507 ZP RAM
so those memory copy instructions can only copy data from ROM into RAM.  I found the RIOT to be interesting, apparently bB passes some, or all, of 6507 ZP RAM to the ARM routines as the ARM has no access to RIOT. I didn't see where this occurs, but didn't spend much time looking.
I also noticed bB is using a different version of my_memcpy, in Space Rocks it's this:
void my_memcpy(unsigned char* destination, unsigned char* source, int count)
	int i;
	for(i=0;i<count;i++)
		destination[i] = source[i];
while in bB it's this:
void my_memcpy(unsigned char* destination, unsigned char* source, int offset, int count)
        int i; //saves a few bytes
                destination[(i+offset)&255] = source[i]&mask;
So it lets you do an offset as a parameter, and mask the data while it gets copied.  Masking the data would let you smoothly move players on/off screen like I do in Stay Frosty 2.  It doesn't look like bB supports that for the players, though I could have easily missed something as I didn't analyze the routines in depth.
The way DPC+ was designed, there's 4K of Display Data in ROM that gets copied to Display Data RAM when the 2600 is powered up.  The data must be in RAM for performance reasons.  If you're writing a DPC+ game using assembly then the graphics are in place ready for use.  If you're writing a DPC+ game that uses ARM/C code then you can reuse the RAM however you want - that's what bB's DPC+ kernel is doing.  So what's going on is bB DPC+ is not using the Display Data RAM like I thought it was.
The actual copying of the sprite data occurs in the ARM/C Code.  It can see the full 32K of ROM, so there is no performance penalty if the data is in a different bank than the 6507 asm routine that sets player0pointerlo/hi.
  • Thanks 2
Thanks, that's making a lot more sense now and i'm starting to understanding how DPC+ uses the graphics data. So it makes complete sense there is no performance loss when the ARM/C code can see the full ROM as a whole. That explains why there is no bankswitching happening no matter where the sprite data is stored. Interesting stuff learning about what's going on in the background ?
9 minutes ago, orange808 said:
Same as this, right?
Yep - I guess @TwentySixHundred hadn't seen that before as he posted this in another topic:
22 hours ago, TwentySixHundred said:
There is also the restriction within DPC+ i forgot to mention of storing graphics data. We are restricted to only being able to store 4k worth of data and haven't the ability to store any graphics data in other banks.
I'm not familiar with bB, and nobody else chimed in that a solution had already been found, so I offered to take a look to see if I could figure it out.
I was planning to look into how to do the same for player1-9 tonight, but now I don't have to so thanks!  Instead, I'll be resuming work on the next entry for my CDFJ tutorial.
Well, drat. I was hoping that if you poked around in the DPC+ kernel innards that you would be tempted to create a CDFJ-based bB kernel to replace it. :P
  • Haha 1
After having a skim read through, looks like i had must of missed that thread. However i do remember noticing the last two posts on Sunday (obviously because i liked them). Having said i think @Lillapojkenpåön was having some issues trying to work out the sprites side of things. So i think this thread was still valuable information to complete the last piece of the puzzle ? Also nothing still has been said about player1 and the virtual sprites ?.
My current plans are to finish the CDFJ Tutorial then resume work on SpiceC, which would be like bB DPC+ but use C instead of BASIC and CDFJ instead of DPC+.  I suspect most of the bB users would be able to figure out SpiceC as a lot of it is very similar.  Instead of bB's:
 if joy0up then p0y = p0y - 1
 if joy0down then p0y = p0y + 1
 if joy0left then p0x = p0x - 1
 if joy0right then p0x = p0x + 1
you'd write something like this:
    if (JOY0_UP)
        player_y[0] = player_y[0] - 1;
    if (JOY0_DOWN)
        player_y[0] = player_y[0] + 1;
    if (JOY0_LEFT)
        player_x[0] = player_x[0] - 1;
    if (JOY0_RIGHT)
        player_x[0] = player_x[0] + 1;
Though most C programmers would use the Increment and Decrement Operators as they take less typing:
    if (JOY0_UP)
        player_y[0]--;
    if (JOY0_DOWN)
        player_y[0]++;
    if (JOY0_LEFT)
        player_x[0]--;
    if (JOY0_RIGHT)
        player_x[0]++;
  • Like 4
That's covered in Reply 9, though it'd be easier to understand as an example in an actual program.  I'll go ahead and do that after work, I'll add a 2nd player that can be moved around with the right joystick.
    if (JOY0_UP)
    if (JOY0_DOWN)
    if (JOY0_LEFT)
    if (JOY0_RIGHT)
    if (JOY0_UP)
        player_y[0]--;
    if (JOY0_DOWN)
        player_y[0]++;
    if (JOY0_LEFT)
        player_x[0]--;
    if (JOY0_RIGHT)
        player_x[0]++;
So with SpiceC the whole program can be written in that C-like syntax or is assembly still needed? What compiler and tools are used? Would Cmake and a standard IDE like Visual Studio Code be fine? I really should have a good read through your tutorials, you probably have already answered these questions ?
I can't wait for SpiceC!!!!!!!!!? An improved kernel for bB could just be a hack of the DPC+ kernel, 9 virtual player0 sprites for example, using the exact same code as for the nine player1's, if there isn't something keeping the kernel to only be in one bank?
and maybe one could change the six playfield reads and playfield color to some other updates more like the slick kernel?
here's some more source material
It would be written in actual C.  No assembly required.
SpiceC is not useable yet, so there is no tutorial for it.  I do have a few blog posts about it:
Do note that the forum upgrade messed up some of the formatting, and I've not gone back to fix the entries.
The C to ARM compiler is Linaro, you'll follow the instructions in Start Here, found in the General forum of the Harmony/Melody Club, to set up a Virtual Machine to use it.
