Captain Spazer Posted January 30, 2020 Share Posted January 30, 2020 (edited) I'm struggling with my math and I could use a little help: The player collides with pfpixel, pfpixel gets turned off, but the collision detection is wonky. The player sprite is 8x8. x = (player0x-18)/4 : y = (player0y)/8 x = (player0x-18)/4 : y = (player0y)/8 if collision(playfield,player0) then pfpixel x y off Entire code: rem Generated 30/01/2020 19:42:08 by Visual bB Version 1.0.0.554 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** start set smartbranching on dim rand16 = z dim _P0_L_R = player0x.k dim _P0_U_D = player0y.l a = 10 player0x = 50 player0y = 10 rem FIX THIS CODE! MAKE IT SPAWN 10 PFPIXELS: Loop_Lettuce d = 0 Place_Lettuce temp1 = (rand&31) temp2 = (rand&7) - 1 pfpixel temp1 temp2 flip d = d +1 if d = 10 then goto main goto Place_Lettuce main COLUP0=$0E COLUP1=$33 COLUBK=$D8 COLUPF= $DC rem PLAYER0 Bunny if a = 10 then player0: %00110100 %00111100 %01111100 %00111110 %00011101 %00000110 %00000100 %00000100 end if a = 20 then player0: %00110000 %00100000 %00011010 %00111100 %00011110 %00001101 %00000010 %00001100 end if a = 30 then player0: %00000100 %00001100 %00011110 %00111101 %01110110 %10100100 %00001000 %00000000 end if a > 30 then a = 0 rem flip p0 sprite if c = 0 then REFP0=0 if c = 1 then REFP0=8 drawscreen rem ANIMATE AND MOVE BUNNY if joy0up then _P0_U_D = _P0_U_D - 0.50 : a = a + 1 if joy0down then _P0_U_D = _P0_U_D + 0.50 : a = a + 1 if joy0left then _P0_L_R = _P0_L_R - 0.50 : a = a + 1 : c = 1 if joy0right then _P0_L_R = _P0_L_R + 0.50 : a = a + 1 : c = 0 if !joy0left && !joy0right && !joy0up && !joy0down then a = 10 rem BUNNY EATS LETTUCE x = (player0x-18)/4 : y = (player0y)/8 x = (player0x-18)/4 : y = (player0y)/8 if collision(playfield,player0) then pfpixel x y off goto main Edited January 31, 2020 by Captain Spazer More info Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 31, 2020 Share Posted January 31, 2020 The numbers are slightly different depending on which direction you move. Make a test program where you turn on pixels, play with the numbers until they are perfect, then use those numbers in your program. 1 Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted January 31, 2020 Author Share Posted January 31, 2020 Ahh, that was very hard, but I got it working now that I understood that the direction of movement mattered. 1 Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted January 31, 2020 Author Share Posted January 31, 2020 While on the subject of math, how would I go about looping the spawn of the pfpixels for example 10 times? My current code seems to be wonky, sometimes I get 8 pfpixels, sometimes 9 and sometimes 10: Loop_Lettuce d = 0 Place_Lettuce temp1 = (rand&31) temp2 = (rand&14) - 1 pfpixel temp1 temp2 on d = d +1 if d >= 10 then goto main goto Place_Lettuce Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 31, 2020 Share Posted January 31, 2020 You could check for a pfpixel using pfread so you never plop on top of a pixel that is already there. Quote Link to comment Share on other sites More sharing options...
