TwentySixHundred Posted February 16, 2020 Share Posted February 16, 2020 16 minutes ago, Random Terrain said: Have you looked at this: randomterrain.com/atari-2600-memories-batari-basic-vbb.html#install_vbb Now that batari Basic comes with, install_win.bat, do not set the bB Environment Variable or the bB Compiler System Path using VbB. Those settings are no longer needed and could cause problems. (There should not be a check mark next to them on the settings page.) From now on, only use install_win.bat to set the variable and path. I will also add if updating from an older version you need to go into bB and remove/delete the old path - save - close bB and rerun the install_win.bat. For some reason the batch file wont overwrite the old existing path and still try to look for that location. Quote Link to comment Share on other sites More sharing options...
