vanman Posted July 21, 2003 Share Posted July 21, 2003 Is it easier to program the lynx with assembly or C? Quote Link to comment Share on other sites More sharing options...
sage Posted July 21, 2003 Share Posted July 21, 2003 Is it easier to program the lynx with assembly or C? C is slower, compiler contains bugs and doe not understand all instructions the lynx can handle. Small games can easiely done in C, but if you want to use hardware and interupts, you should switch to ASM. If you use C you have to use a (imo bad) Inline Assembler. This is because not everything is yet converted to a library function. Example: One of my games started as C. Now only the game-logic and the frame is done in C, everything else in inline-asm. Just compare my (very easy) examples: http://www.uni-giessen.de/~gd1113/lynx/kurs/ Tschau, Sage Quote Link to comment Share on other sites More sharing options...
lucienEn Posted July 22, 2003 Share Posted July 22, 2003 Also usually you use ASM for performance reasons. C is easier to read and to code but it's slow and takes up more space. I also usually use C and then use a lot if inline ASM (especially at a later phase where you need better perf). Quote Link to comment Share on other sites More sharing options...
eric_ruck Posted July 23, 2003 Share Posted July 23, 2003 You can also like assembly modules to C modules. Depending on the size and speed needs of your game I'd do as much as possible in C, unless you happen to have a whole lot of time on your hands. Especially if you're new to programming, I think you would have a better change of success if you at least start with C so you can begin to see results as your game takes shape. The C compiler produces assembler output as an intermediate format. You can also use that intermediate output as a starting point for assembly language -- even though the output is way less than optimal, you can always pick through and improve the parts that need it. Eric Quote Link to comment Share on other sites More sharing options...
sage Posted July 24, 2003 Share Posted July 24, 2003 The C compiler produces assembler output as an intermediate format. You can also use that intermediate output as a starting point for assembly language -- even though the output is way less than optimal, you can always pick through and improve the parts that need it. Not really. I woulnt recommend using the ASM output as a starting point. And remember: The BLL Lyxass has a bit library of powerful macros and functions. But it is not compatible to the inline asm. But... it's your choice. Tschau, Sage Quote Link to comment Share on other sites More sharing options...
