mrdweeb Posted May 27, 2020 Share Posted May 27, 2020 I just got the netusbee running on my 1040st and it works fine transferring files. Now I would like to set up other networking options. I'm trying to follow the instructions on ataridotorg. I'm having trouble finding all the drivers for STing, specifically the ethernec/netusbee driver, which apparently an stx file. According to other posts here, sting should run ok on my 1 meg machine. Any help would be appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Mark_G Posted May 27, 2020 Share Posted May 27, 2020 Network related items : Did you follow the info according following sites : http://hardware.atari.org/manuals/netsoft.htm http://hardware.atari.org/manuals/netsting.htm Download links mentioned on this site are still working. For the latest revision of the UIP tool https://bitbucket.org/sqward/uip-tools/downloads/ USB related items : usb driver pack revision 5 On atari-forum.com However this is down. Maybe somewhere else, but I don't know. Quote Link to comment Share on other sites More sharing options...
mrdweeb Posted May 28, 2020 Author Share Posted May 28, 2020 I finally found the ethernec files and installed them. Sting loaded from the auto file of my c drive. Now I have a problem that the sting control panel port settings won't open. Any idea what's wrong? Quote Link to comment Share on other sites More sharing options...
Mark_G Posted May 28, 2020 Share Posted May 28, 2020 (edited) You have installed xcontrol.acc ? http://www.atari-wiki.com/index.php/The_"XControl.ACC"_Control_panel_and_CPX_modules_explained For installation of sting, see also : http://www.mega-ste.com/netusbee_n_sting.htm And don't forget to point xcontrol to the right cpx directory. Use editor QED for the configuration of DEFAULT.CFG and ROUTE.TAB. At ROUTE.TAB, you need to separate the items with TAB, do not use spaces. Further, I used always : EtherNet With capital E and capital N More information : https://weblambdazero.blogspot.com/2016/04/netusbee-configuration-for-atari.html Good luck, Mark Edited May 28, 2020 by Mark_G Quote Link to comment Share on other sites More sharing options...
mrdweeb Posted May 28, 2020 Author Share Posted May 28, 2020 Mark, thanks a lot for this. This is the most complete information on sting installation that i've seen. Well, back to the drawing board Quote Link to comment Share on other sites More sharing options...
