+Karl G Posted June 24, 2020 Share Posted June 24, 2020 I got my Seagull78 adapters today, and got these to work with my rarely-used retro NES-style Switch joycons. It works great, and I'm quite happy with the setup! Just as a note, I had to update my receivers to the latest firmware version before they would pair with the controllers. I had issues getting the Mac firmware updaters to work, so I had to do the update from a Windows VM. 3 Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 19, 2020 Author Share Posted July 19, 2020 Just a heads up that there's a new USB/Bluettooth controller adapter being worked on. It's based on Raspberry Pi zero, and the software will be open source. There's a proof of concept running, and it already includes support for the 7800. (2600, 5200, etc.) While it's early days yet, this will go beyond what the 8bitdo adapter is capable of. Dual sticks, no problem. Controller mashups, no problem. Emulation of rarer controllers, no problem. If this is the sort of thing you're interested in, follow the link, vote in the poll, maybe make a comment. 4 Quote Link to comment Share on other sites More sharing options...
boxpressed Posted July 29, 2020 Share Posted July 29, 2020 The 8BitDo BT adapters are only $11.47 now on Amazon. 1 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 22, 2020 Share Posted September 22, 2020 Its back to 15.97 now. There is this also. Anyone try this? http://retro-bit.com/sega-genesis-betooth-receiver.html Quote Link to comment Share on other sites More sharing options...
Shawn Posted September 22, 2020 Share Posted September 22, 2020 1 hour ago, 0078265317 said: Its back to 15.97 now. There is this also. Anyone try this? http://retro-bit.com/sega-genesis-betooth-receiver.html That looks like a pretty good deal. Quote Link to comment Share on other sites More sharing options...
+MrZarniwoop Posted December 5, 2020 Share Posted December 5, 2020 I just wanted to note that the combination of: Seagull 78 Controller Adapter ($25 USD) + Retro Receiver for SEGA Genesis & Mega Drive ($20 USD, but often on sale for less) + N30 Bluetooth® controller for Switch Online ($25 USD, although bit hard to find right now) ... works great on my Atari 7800. It's an NES-style gamepad that is small and light, A/B fire buttons work with two-button 7800 games, and it's nice where mashing a fire button can produce a volley of shots using the turbo A/B buttons. The only hassle is restoring the Bluetooth connection after powering the 7800 on/off to change games, as the fastest way to reconnect wirelessly is about 5 seconds where you turn the N30 gamepad off (hold "start") and then on again (press "start"). 1 1 Quote Link to comment Share on other sites More sharing options...
Zonie Posted December 21, 2020 Share Posted December 21, 2020 These are cool, BUT, I want to use my own handmade and modded controllers with it. Anyone know if there is a "paired" set that you plug the receiver into the console, and the transmitter into your controller? Quote Link to comment Share on other sites More sharing options...
Lectronimo Posted December 23, 2020 Share Posted December 23, 2020 I was able to get the new 8bitdo Arcade Stick that I bought to use with my Nintendo Switch to work with the Seagull 78 and Retro Receiver on my 7800. I also replaced the guts of the arcade stick with an upgraded Sanwa joystick and Ultimarc concave gold leaf buttons. Had to solder a 5-pin harness onto the board for the Sanwa but it was pretty simple to do. The arcade style buttons were a tight fit and tricky to get in there, but with some time and patience, I was able to get everything to fit. Anyway, it's great! When you pair it, it has to be in Switch mode. I suppose if you had your own homemade controller enclosure, I don't see why you could not use the boards out of the arcade stick and put them into something else. Quote Link to comment Share on other sites More sharing options...
Atarifan2021 Posted December 30, 2020 Share Posted December 30, 2020 It’s great to have Bluetooth capability for my 7800, though using my Xbox controller for games such as Pac-Man can be a bit challenging with game movements and such Quote Link to comment Share on other sites More sharing options...
