plane vuki Posted June 17, 2020 Share Posted June 17, 2020 Hello. My Atari STfm was working good. I was using it with a tv-out. Today I decided to connect it VGA monitor (CRT) for hi-res and sharp image. Surfed around the internet, learned how to do, connected grounds to grounds, vsync to vsync, hsyne to hsync, and for a start: mono to green. For about 10 miniutes everything was good, got hi-res and sharp image. Then suddenly: blurry, and goes on like that. Restart: same. Mono to red/blue:same. I thought maybe my CRT is damaged for some reason, tested with PC: everything looks good. I thought maybe something wrong with ST, tested it with TV-out: blurry + colors are "not good". Any idea what went wrong and what can be done? I have a suspicion that not using a resistor at mono-out might have slightly damaged something inside? Thanks in advance. (Attached photos showing blurry image on CRT, mono to green in this case) Quote Link to comment Share on other sites More sharing options...
plane vuki Posted June 18, 2020 Author Share Posted June 18, 2020 Update: It was still showing bad image, nothing fixed it. Then I decided to look inside for visible damage or burn on any components. Dissassembled: all look good, moral is low, feel very bad. Assembled back, tested: everything is good again! Huh what was that all about? My ST is in very good condition overall, very clean and no visible damages to anything. I have no idea why it suddenly showed blurry and after dissassembly+reassembly was back to normal. I think it wasnt due to not using resistor, but from now on I will for any case. Why this happened I have no idea, what was the reason. Maybe some static build up? I remember it happened when my one hand was touching ST, with other hand I toiched CRT to adjust it. If you have any idea please let me know. But for me, lessons learned so far: Use resistors, dont touch CRT and ST at the same time. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 18, 2020 Share Posted June 18, 2020 It was rather some contact error, dry joint. Possible that will happen again. Cure: reseat chips in sockets (shifter), resolder especially video connector. 2 Quote Link to comment Share on other sites More sharing options...
