foxmulder900 Posted July 11, 2020 Share Posted July 11, 2020 Any tips on repairing these keys? It's the only one on the board that doesn't register, so I just de-soldered it hoping to just be able to clean up some corrosion or something. However it doesn't seem to want to come apart any further and I don't want to force it for fear of breaking it. Quote Link to comment Share on other sites More sharing options...
archeocomp Posted July 12, 2020 Share Posted July 12, 2020 I measured resistance on non workin one and it was around 100-150Ohm. How much is yours? I then sprayed some contact cleaner in the litle holes. No change. Then I desoldered it. Suddenly it measured 0Ohm. Heat (and possibly cleaner) fixed it. I soldered it back, job done. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted July 12, 2020 Share Posted July 12, 2020 Cleaning plus heat works wonders. 1 Quote Link to comment Share on other sites More sharing options...
foxmulder900 Posted July 13, 2020 Author Share Posted July 13, 2020 That worked! I just used some contact cleaner and was getting 0Ohm (not sure what it was before), re-soldered and all is well. Thanks a ton! Quote Link to comment Share on other sites More sharing options...
Sugarland Posted July 13, 2020 Share Posted July 13, 2020 7 hours ago, foxmulder900 said: That worked! I just used some contact cleaner and was getting 0Ohm (not sure what it was before), re-soldered and all is well. Thanks a ton! This fix is out there. 1 Quote Link to comment Share on other sites More sharing options...
Mr Interrupt Posted July 22, 2020 Share Posted July 22, 2020 (edited) Does anyone have any of internal key white plastic actuator for an 800XL, please? I discovered my 800XL suffered from a loft shuffle! Edited July 22, 2020 by Mr Interrupt Could not see picture. Quote Link to comment Share on other sites More sharing options...
