Senneman Posted July 30, 2020 Share Posted July 30, 2020 ... because hyperkin can't help me, I turn to the community! ? This console seems to have a life of its own. As if he chooses when he wants to work or not. First of all: the included SD card was damaged. Both the R77 and my computer were unable to read it. So I put another SD card (with the Hyperkin firmware) in the console and that seemed to work. Yes! A day later I ran into another problem: the console just won't start. Switching on and off ten times seemed to work for a while. But after that it really didn't work anymore ... example After some research on this forum I came up with a 'community build' Stella 6 firmware. I flashed this firmware on the SD card. And wow! SO MUCH BETTER ? !!! and the Retron 77 did it again. But then I ran into the same problem again: the Retron 77 stopped working a day later ... but after re-preparing the SD card with Stella 6, it worked again. And then a day later ... again the same problem. I've already tried several things: all older firmwares (including the Hyperkin firmware). Every time the Retron stopped working a day later. So weird! It doesn't make any sense ?!!! I also don't find any of these bugs on the internet. I would also like to unscrew the console to view the circuit board, but I'm afraid I will lose my warranty. Does anyone ran into the same issue? Quote Link to comment Share on other sites More sharing options...
fluxit Posted August 20, 2020 Share Posted August 20, 2020 (edited) Try a different USB power supply and/or HDMI cable if you can. Edited August 20, 2020 by fluxit Quote Link to comment Share on other sites More sharing options...
Senneman Posted August 22, 2020 Author Share Posted August 22, 2020 Thank you for the reply ? Unfortunately, I tried all of that. Different usb hub, usb cable, hdmi cable, different tv port, ... none of these did the job. In the meantime they have already sent me a new R77. And this one does it perfectly! 1 Quote Link to comment Share on other sites More sharing options...
