Randy Posted September 6, 2020 Share Posted September 6, 2020 the internal connector in the Mega st for, maybe a hard drive or something? The small fan in my Mega ST is kaput, any recommendations for a replacement? Thanks Quote Link to comment Share on other sites More sharing options...
MasterMotorola Posted September 6, 2020 Share Posted September 6, 2020 I recently replaced the PSU fan in my TT with a Noctua and it's silent now. 1 Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted September 6, 2020 Share Posted September 6, 2020 (edited) There are 2 internal connector in MegaST. One is the MegaBus besides the 68k chip and can be used for all sort of things, IDE HDD is on of them. The other is an internal ACSI connector for HDD, located behind the 19 pin D-Sub connector. MegaST uses a smaller fan then the ones in MegaSTe and TT. Edited September 6, 2020 by snarkdluG 1 Quote Link to comment Share on other sites More sharing options...
Randy Posted September 6, 2020 Author Share Posted September 6, 2020 7 hours ago, snarkdluG said: There are 2 internal connector in MegaST. One is the MegaBus besides the 68k chip and can be used for all sort of things, IDE HDD is on of them. The other is an internal ACSI connector for HDD, located behind the 19 pin D-Sub connector. MegaST uses a smaller fan then the ones in MegaSTe and TT. Thanks guys! BTW, you are right, I didn't see the internal ACSI at first, got it. The Megabus, to use an IDE HD I would guess I need some kind of adapter? Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted September 6, 2020 Share Posted September 6, 2020 2 hours ago, Randy said: Thanks guys! BTW, you are right, I didn't see the internal ACSI at first, got it. The Megabus, to use an IDE HD I would guess I need some kind of adapter? Yes, it's a PCB with the MegaBus connector underneath and you have an 40 pin IDE connector on top. It also have a 256K decoder on it for using TOS 2.06 ROMs for example. The board design can be found on ParanoidLittleMans homepage. The board has no buffers so you can't use long cables. You also need to program a GAL. You can see the board attached in a MegaST in an other thread in this forum. I don't know if anyone is selling these. Quote Link to comment Share on other sites More sharing options...
