TonySoprano Posted August 2, 2003 Share Posted August 2, 2003 I just got my cable recently and now I got some time to fool around with some games on the Atari. I am trying out the APE software with DOS 2.5 and managed to get it booted, but how do I run games? I managed to get a few running, but many don't..i get some errors like 165 , or sometimes it locks up completely. Is there some sort of DOS guide I can read about ?? I totally forgot how to use this DOS 2.5 or MyDOS... It was like 20 years ago! oh ya I'm running on a XEGS too, so that might explain some of the lock ups. Quote Link to comment Share on other sites More sharing options...
emkay Posted August 2, 2003 Share Posted August 2, 2003 Here are the standard ERROR-Messages: 128-BREAK key abort 132-Invalid command 136-End of file 137-Truncated record 138-Device timeout 139-Device NAK 140-Serial bus error 142-Serial bus data frame overrun 143-Serial bus data frame checksum error 144-Device done error 145-Read after write compare error 146-Function not implemented 160-Drive number error 161-To many open files 162-Disk full 163-Unrecoverable data I/O error 164-File number mismatch 165-File name error 166-POINT data length error 167-File locked 168-Command invalid 169-Directory full 170-File not found 171-Point invalid 173-Bad sector at format 255-Format error Quote Link to comment Share on other sites More sharing options...
emkay Posted August 2, 2003 Share Posted August 2, 2003 Because of your Filename error : To copy files, you have to use the following syntax d:filename.ext,d2:filename.ext Please take note about the comma. The Filename is allways 8 characters. Quote Link to comment Share on other sites More sharing options...
TonySoprano Posted August 2, 2003 Author Share Posted August 2, 2003 thanks emkay, that error list will help me out. I managed to get a few games working by disabling BASIC first with the option key (wow, I forgot about that) so I think I got the hang of it. The cable to the PC seems a little unreliable though, does it often fail to detect the PC? sometimes I boot the Atari and it goes staight to SELF TEST instead of DOS. Sometimes it will give me an error in the middle of listing a directory. Seems like i have to retry 2 to 3 times before it works properly. Quote Link to comment Share on other sites More sharing options...
