zezba9000 Posted December 14, 2020 Share Posted December 14, 2020 Do some games like Bubble Bobble, etc require it to be launched from disk-drive A? Bubble Bobble launches fine on my Atari ST 520 as it only has an external drive (which is drive A) BUT it fails on my Atari 1040 STF when I launch it from external drive B. I can make a A/B drive enable swap switch like I did for my Apple /// but want to confirm this is actually the issue first. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted December 14, 2020 Share Posted December 14, 2020 There is plenty of games which are coded so, that can be started only from drive A: . So, yes, it is worth to make that switch. 1 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted December 16, 2020 Share Posted December 16, 2020 Yep that’s why a lot of people are having problems with a GOTEK hooked up to their Atari STF computers as drive B: Quote Link to comment Share on other sites More sharing options...
zezba9000 Posted December 17, 2020 Author Share Posted December 17, 2020 So for my Apple /// with FloppyEmu I did the mod so it didn't touch the hardware and modified custom ribbon cables to swap drive-enable lines. You can see that here: https://68kmla.org/forums/topic/60583-apple-iii-floppy-emu/?do=findComment&comment=651569 Now I'll have to decide if I want to use the same method for my Atari STF but that might be harder on this computer because of the external cable. Quote Link to comment Share on other sites More sharing options...
