fultonbot Posted December 14, 2020 Share Posted December 14, 2020 (edited) I don't know if this is useful to anyone else, but I built a tool to help me figure out what pokey sounds on the 7800 It lets me test out sound mixing on all four channels at the same time. Controls: -Joystick/arrow keys select the value to change (orange) -Left button increases value, right button decreases value - F = Frequency -W =Waveform -V = Volume (needs to be > 0 to hear anything) -D = Duration (how many frames to play the sound) -S = Silence (amount of time between plays to keep channel silent) -T = Type (C)onstant (play at same volume), (A)attack (play from volume 0 to 15, (D)ecay (play from volume 15 to 0) This is s the first version. Suggestions much appreciated. link: JS7800: Atari 7800 Emulator (raz0red.github.io) There may well already be a tool like this, but this is mine. I used to help me understand the pokey chip and what it can do. I think I probably made something similar to this in Atari 8-bit BASIC back in the 1984 or 1985 for the same purpose. pokeyplayer2.bas.a78 pokeyplayer2.bas.bin Edited December 14, 2020 by fultonbot 5 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted December 15, 2020 Share Posted December 15, 2020 Very impressive. There are a couple of other registers which shape the sound too ... AUDCTL (POKEYADDR + $08) There are 8-bits to this register. These control everything from clocking (which can let you play your channels at higher or lower frequencies), hi-pass filter (an effect which lets you use one channel to modulate the waveform of the other), 16-bit mode (joining two channels into a 16-bit one to extend the musical range), and a 9-bit polycounter (for playing musical notes on the $0x and $8x waveform settings). SKCTLS (POKEYADDR + $0F) This one is more complicated. It acts on the first two channels. Default is $03. Storing $8B here activates two tone mode where the frequency of the 2nd channel is played to the first channel, plus a modulation from the first channel. It was used in the old Atari 8-bit days for cassette I/O. Both of these have varying issues of compatibility when it comes to emulation, though ... 2 Quote Link to comment Share on other sites More sharing options...
fultonbot Posted December 15, 2020 Author Share Posted December 15, 2020 1 hour ago, Synthpopalooza said: Very impressive. There are a couple of other registers which shape the sound too ... Yeah, I did read about those, but they stretched my brain too-far to try to implement just yet. I think once I realize I can't do what I need with the 8-bit Pokey, I'll be on to the 16-bit stuff. Quote Link to comment Share on other sites More sharing options...
