tjlazer Posted January 1, 2021 Share Posted January 1, 2021 So here is a strange one! Been having a hard time trying to find a working copy of Spy vs Spy and none seem to work. Even on Patari's site the one on there doesn't work right. Locks up once it starts. I spent some time trying to hunt down different versions and the only one that works is the Pasti version, and some of the others might start but they all seem to crash right after the game begins before you leave the first room. (see screen shot) Anyone have a working copy? Spy vs Spy II and III seem to work perfectly from here btw: http://atari.8bitchip.info/fromhd2.php?s=n#DL Spy Vs Spy - AOD.zip Spy vs Spy.zip Spy vs Spy - Ppera.zip Spy vs Spy (PAL).zip Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 1, 2021 Author Share Posted January 1, 2021 EDIT. I just tried with a UK TOS and the game seems to be working! So it's must be a region/PAL issue after all. So now we need a NTSC fixed version Quote Link to comment Share on other sites More sharing options...
leech Posted January 3, 2021 Share Posted January 3, 2021 On 1/1/2021 at 1:15 PM, tjlazer said: EDIT. I just tried with a UK TOS and the game seems to be working! So it's must be a region/PAL issue after all. So now we need a NTSC fixed version Ha, I wasn't even aware the ST had Spy vs Spy, I only ever played them on the 8bit. interesting it is borked on NTSC, I thought it was released by an American company. Have you tried loading it after loading a 50hz switcher? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 4, 2021 Share Posted January 4, 2021 There is US release of Spy vs Spy : http://www.atarimania.com/game-atari-st-spy-vs-spy_11345.html Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 4, 2021 Author Share Posted January 4, 2021 40 minutes ago, ParanoidLittleMan said: There is US release of Spy vs Spy : http://www.atarimania.com/game-atari-st-spy-vs-spy_11345.html This must not be the US release as it locks up with USA TOS. Works with UK TOS. Quote Link to comment Share on other sites More sharing options...
ijor Posted January 4, 2021 Share Posted January 4, 2021 I don't think there is an US release of Spy vs Spy for the ST, or at least I never seen it. The Pasti image at Atarimania is actually the Uk Databyte release. 1 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 4, 2021 Author Share Posted January 4, 2021 Then we need a proper fix/crack then Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 4, 2021 Share Posted January 4, 2021 Yes, that STX image on linked page is not US version, so Atarimania mistake. What Pasti version worked for you ? What TOS version (region/lang. data needed too) used and which emulator ? When exactly it locks up ? Quote Link to comment Share on other sites More sharing options...
leech Posted January 4, 2021 Share Posted January 4, 2021 1 hour ago, tjlazer said: Then we need a proper fix/crack then Need one with a 50hz bootloader? Quote Link to comment Share on other sites More sharing options...
.mad. Posted January 5, 2021 Share Posted January 5, 2021 This version works for me in Hatari with TOS104US TV60Hz. Spy vs Spy.zip Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 11, 2021 Author Share Posted January 11, 2021 On 1/5/2021 at 9:13 AM, .mad. said: This version works for me in Hatari with TOS104US TV60Hz. Spy vs Spy.zip 93.77 kB · 9 downloads Doesn't work, same issue. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 11, 2021 Share Posted January 11, 2021 I tested diverse releases in Steem and real HW (Mega STE). The thing is that it just works not at 60 Hz refresh rate. When entering other room players disappear. Some timing problem of code. Tried with CPU at 16 MHz on Mega STE, and it helped not, + game was unplayable in single room too. So, only solution is to set machine to 50 Hz before playing. Then it works with all TOS versions up to 2.06 US . Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 12, 2021 Share Posted January 12, 2021 Made new releases, with switching refresh rate to 50 Hz at start of game: http://atari.8bitchip.info/ASTGA/S/spyvsp.php http://atari.8bitchip.info/SCRSH/spy1s.html 2 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 14, 2021 Author Share Posted January 14, 2021 Thank you the game now runs fine! Quote Link to comment Share on other sites More sharing options...
