+SpiceWare Posted August 5, 2003 Share Posted August 5, 2003 Just finished hacking my supercharger and have been having a blast. I used The Empire Strikes back as the "test", it wouldn't work before I did the mod, but works now when the switch is in the proper position. However, Air-Sea Battle is misbehaving. The collision detect routines appear to be hosed - shots will either travel thru all targets w/out registering a hit, or they will hit a lower target but explode the topmost target. Anybody else seen this? A search of the forums didn't turn up anything. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted August 5, 2003 Share Posted August 5, 2003 Just finished hacking my supercharger and have been having a blast. ... However, Air-Sea Battle is misbehaving. Yeah .. Air-Sea Battle, Haunted House and a few other games do not work with the modified Supercharger. Chad Schell knows what causes this problem .. and the Cuttle Cart hardware/ software corrects this problem for Cuttle Cart owners. But this doesn't help you .. Still ASB and HH are common carts anyway. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 5, 2003 Author Share Posted August 5, 2003 Thanx! I was concerned I might have done something wrong during the mod. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 5, 2003 Author Share Posted August 5, 2003 Found a solution on the Stella list - Air-sea battle on SC - solved! It turns out that Air-Sea battle reads the images of the collision registers at $00/$01, as opposed to $30/$31. It looks like the SC interferes with the mapping of the read-registers, maybe because they overlap the write-registers there? At any rate, patching the code to use the images at $3x makes it work on the supercharger. Specifically for Air-Sea Battle, offset $00b9: $00->$30 offset $00bd: $01->$31 offset $004a: $00->$30 Also turned up references to Haunted House, Space War and Ghost Manor not working, as well as Breakout which must be doubled up to a 4K image to work. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 6, 2003 Author Share Posted August 6, 2003 didn't work no difference changing locations 00b9 and 00bd. Location 004a has a 01, not a 00, and changing it causes a crash. I ran it thru Distella and it looks like the 004a should have been 024a, but changing it didn't help either. Quote Link to comment Share on other sites More sharing options...
cschell Posted August 6, 2003 Share Posted August 6, 2003 The collision detection problem with the Supercharger and some games is caused by a bus timing error on the Supercharger's part. That much I know, but I don't know why that bus timing error creates a problem in a few games but not in others. Unfortunately I don't think the bus timing error can be fixed, but altering the ROMs seems like a clever way around the problem. Too bad the fix you mentioned above didn't work. Chad Quote Link to comment Share on other sites More sharing options...
