mrdweeb Posted January 11, 2021 Share Posted January 11, 2021 I am having trouble partitioning my sd card for use on Ultrasatan. Machine: Mega 2 TOS: 1.02 Driver/partitioner: P. Petari, latest version 1 imaged 16 gb sd card with 15mbuvf.img 2 booted ST and opened PPPMBUF.pgm 3 Clicked on ACSI 0 4 changed information from 14mb to 512 mg (later to 256mg when 512 did not work) on 4 or 5 of the drives. 5 Clicked PARTIT and INIT all 6 clicked back to Drive 0 Shows no new information, only 14 mg on drive C as before What am I doing wrong? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 12, 2021 Share Posted January 12, 2021 Couple people sent me recently photos of SD cards which worked not with UltraSatan: Sandisk at left works, one at right, with that 1 in U not. Shown Transcend works not too. I guess that they have some new characteristics, and that's the reason. As is known there are problems with diverse cards in USB readers too, so UltraSatan is not something especially picky. I can say that what I have and tried everything works - about 10 years old 1 GB Kingston up to some 4 months old 64 GB Kingston Micro SD. Of course no sense to use so large capacity with old Ataris - there are TOS limits: Max 14 partitions C-P (that's total number, so if you attach 2 cards sum of partition counts is it too (like 8+4) . If there is more, later partitions will be not mounted. Max partition size is 512 MB for TOS 1.04 and later. 256 MB for TOS 1.00 and 1.02 . And that's answer for why you was not able to set 512 MB size. It seems that write to card works not at all. If someone has problematic SD card with UltraSatan, would be good to post here about it, possibly with photo. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 12, 2021 Share Posted January 12, 2021 I use the 8 Bit Forum too, even there, with all the devices we now have to enhance the 8 Bit, the main issue that seems to crop up very often is the choice of SD cards of all types, the main thing that was found is in general SanDisk seems to work most of the time. With the recent release of SIDE3 there were many people having issues with SD cards, but we were lucky @flashjazzcat who develops the SIDE3 software made many changes to allow a wider range of SD cards to work, maybe whoever supports Ultrasatan could do the same. Quote Link to comment Share on other sites More sharing options...
mrdweeb Posted January 12, 2021 Author Share Posted January 12, 2021 Thanks for the suggestions. Of course I can use the 14 mg partition C drive until I find another solution. That's actually enough for most of my stuff. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted January 12, 2021 Share Posted January 12, 2021 Another recommendation - upgrade your TOS to v1.04. You'll get multiple advantages, including the larger partition size, faster speed, reliability, and lots of desktop improvements. On that machine, should be very simple TOS chip swap out. Either 2 chips or 6... Quote Link to comment Share on other sites More sharing options...
mrdweeb Posted January 12, 2021 Author Share Posted January 12, 2021 Good idea! Quote Link to comment Share on other sites More sharing options...
