+9640News Posted January 18, 2021 Share Posted January 18, 2021 I have the SCSI card shown below. I'm using it on my Geneve. Tim mentioned there may be an update for this board? It is a Revision F, Serial #74, with a V1.1 eprom. Thanks for any feedback, etc. 2 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 18, 2021 Share Posted January 18, 2021 (edited) FWIW, I show two other DSRs in my inventory - Vn 1.05 and Vn 1.06. The Vn 1.1 that I have is listed as a "field trial". Edited January 18, 2021 by atrax27407 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 18, 2021 Share Posted January 18, 2021 (edited) Hi, my latest one is the v1.6-0 dated 26.Mar.1999 dsr-v1.6-0b.zip And there is an v1.5-0 - 14.Mar.1998 The "Field Test v1.1" is 25.Oct.1995 I don´t know if any DSR-revision works with any hardware revision... But I think so. And I have something that is called ´sources´, from 2001 Edited January 18, 2021 by Schmitzi 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 18, 2021 Author Share Posted January 18, 2021 There was a comment I heard this card may have used a daughter board, and some of those eprom versions required the daughter board. Beery Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 18, 2021 Share Posted January 18, 2021 A warning I know Rich had an issue where his card got upgraded and then it wouldn't read any of his drivesSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RickyDean Posted January 18, 2021 Share Posted January 18, 2021 There was a scsi thread back s couple if years ago here. Do some search, should be able to find easily enough, I'm doing some welding today and can't search for it. 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 18, 2021 Share Posted January 18, 2021 Michael Becker made a daughter board to properly implement the DMA functionality. I believe it was usable on Revision "F" and "G" cards. It isn't needed for the ASCSI cards from SNUG, as the capability is already integrated in the main design. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted January 18, 2021 Share Posted January 18, 2021 4 hours ago, Schmitzi said: don´t know if any DSR-revision works with any hardware revision... But I think so. As I recall, V1.5 is the latest non-PDMA/modified version and 1.6x was released for the PDMA-capable cards. The card driver low level routines are not interchangeable though the other banks of level 1,2,3 code are nearly the same. At minimum, I would think Beery should update to 1.5 I have a "F" and "G" card; @Shift838 has an "E" card of mine that was never modified, the intent was to keep it that way to test MDOS with older cards. Beery and I discovered this morning that he had an older card and it definitely needs the older non-PDMA support ? I wonder how many of the E and F cards were updated with Michael Becker's changes? Any mods left? @Swim 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 18, 2021 Author Share Posted January 18, 2021 So, if I understand things, I can upgrade to Version 1.5, but would need the daughterboard for V1.6? Is the daughterboard available anywhere? Does it require any soldering on the card or trace cuts, or is it just a board that plugs into a socket? And, with the comment about changes in the low level routines, does that mean a reformat of partitions? Beery Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted January 18, 2021 Share Posted January 18, 2021 2 hours ago, BeeryMiller said: And, with the comment about changes in the low level routines, does that mean a reformat of partitions? Even if the partitions were the same, it wouldn't be a bad idea to reset them. My only experience with an older EPROM was v0.7. Does anyone know if v1.1 was stable? Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 19, 2021 Share Posted January 19, 2021 I have two copies (appear to be identical code) - one is marked "field test" and the other is, I suspect a final copy. Quote Link to comment Share on other sites More sharing options...
humeur Posted January 19, 2021 Share Posted January 19, 2021 I have a Scsi card With the card that replaces the two Gal. I'm looking for a copy of these gal or just the equation file. If need the eprom dump ask me. Thank Jean louis 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 20, 2021 Author Share Posted January 20, 2021 8 hours ago, humeur said: I have a Scsi card With the card that replaces the two Gal. I'm looking for a copy of these gal or just the equation file. If need the eprom dump ask me. Thank Jean louis I guess its unlikely this daughterboard replacement is available anywhere??? Beery Quote Link to comment Share on other sites More sharing options...
+dhe Posted January 20, 2021 Share Posted January 20, 2021 FWIW - Don O'Neil was having troubles tracking down some very intermittent problems people were having with the SCSI controller, and he sent some to Michael Becker to be diagnosed. Michael had already encountered the problems the WHT SCSI Controller was having in his own designs and that was the quick reaction time from modern chips set. In a condensed version, what he said was, the TI is relative slow and by the time the TI transitioned from one logical state to another, the newer chips are ready for many different changes in state, so any momentary glitch, the newer chips say - ah.. we need to transition states. So Michael designed the daughter cards to tell newer chips, just hold your state until the TI and it's bus are REALLY ready to change states! I don't think you will see anymore of these cards, Don sent a bunch of SCSI Controller cards to Michael to be upgraded, you can tell by the hand writing on some of the EPROMs. So, can't help with the board, but maybe you liked the history? ? 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 21, 2021 Share Posted January 21, 2021 I think Michael may have also sent a bunch of the daughter boards to the US to allow upgrades of existing cards. I think they may have gone to Richard Bell, as he's the US SNUG liaison, but they could also have gone to Don. 3 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 21, 2021 Author Share Posted January 21, 2021 How do I contact Richard Bell? 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 21, 2021 Share Posted January 21, 2021 2 hours ago, BeeryMiller said: How do I contact Richard Bell? He's @Swim here on the forum. 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 21, 2021 Share Posted January 21, 2021 I pinged Richard on facebook and asked him to peek in here. He's pretty busy with real life right now though so set your expectations accordingly. Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 21, 2021 Author Share Posted January 21, 2021 I sent him an email as well and he mentioned your note. Things will happen, when they happen. Family and work take priority over any hobby. 1 Quote Link to comment Share on other sites More sharing options...
Swim Posted January 21, 2021 Share Posted January 21, 2021 I think I explained the WHT SCSI controller history here on AA in an SCSI thread a while back so a search for the long version of the history can be found if needed. Here's the short version on the WHT SCSI controller series history. I was the authorized WHT repair/upgrade station here in the USA until Competition Computer bought the rights for the WHT SCSI series "E", "F" and "G" boards. At that point Don requested I ship all remaining boards/chips I had to him and he shipped that inventory to Competition Computer as part of the sale. At this point any upgrades/runs of boards will need the permission of Competition Computer. Although many of the original "E", "F" and "G" cards did function on the Geneve most did not on the 99/4a. The 1.6 upgrade gave all three card verisons very stable operation characteristics with all available popular hard drives including ZIP and Syquest EZ-135 units. Hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 21, 2021 Author Share Posted January 21, 2021 2 hours ago, Swim said: I think I explained the WHT SCSI controller history here on AA in an SCSI thread a while back so a search for the long version of the history can be found if needed. Here's the short version on the WHT SCSI controller series history. I was the authorized WHT repair/upgrade station here in the USA until Competition Computer bought the rights for the WHT SCSI series "E", "F" and "G" boards. At that point Don requested I ship all remaining boards/chips I had to him and he shipped that inventory to Competition Computer as part of the sale. At this point any upgrades/runs of boards will need the permission of Competition Computer. Although many of the original "E", "F" and "G" cards did function on the Geneve most did not on the 99/4a. The 1.6 upgrade gave all three card verisons very stable operation characteristics with all available popular hard drives including ZIP and Syquest EZ-135 units. Hope this helps. Which versions of the EPROM for the F can be used without a daughterboard upgrade? Quote Link to comment Share on other sites More sharing options...
Swim Posted January 21, 2021 Share Posted January 21, 2021 1 hour ago, BeeryMiller said: Which versions of the EPROM for the F can be used without a daughterboard upgrade? All EPROM versions prior to 1.6 may or may not work but are more likely to work using the Geneve than the 99/4a. The 1.6 EPROM should not be used without the complete upgrade which requires different hardware modding for each card in the series. Quote Link to comment Share on other sites More sharing options...
+dhe Posted January 21, 2021 Share Posted January 21, 2021 Hey brainy guys and gals. What's the best SCSI drive replacement? I have a number of syquest and zip drives hooked to my SCSI controller. I'd like to use an SD card as storage, so I can just do a backup by pluging in to a pc, and using some of the great tools that are available to work on images. Thanks! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 21, 2021 Share Posted January 21, 2021 Hey brainy guys and gals. What's the best SCSI drive replacement? I have a number of syquest and zip drives hooked to my SCSI controller. I'd like to use an SD card as storage, so I can just do a backup by pluging in to a pc, and using some of the great tools that are available to work on images. Thanks!Scsi2sdSent from my LM-V600 using Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 22, 2021 Share Posted January 22, 2021 That said on the parts availability, Kyle Crichton of Competition Computers is still active on eBay (mostly with Vectrex stuff). Contacting him may have results. 3 Quote Link to comment Share on other sites More sharing options...
