1200XL M.U.L.E. Posted March 26, 2021 Share Posted March 26, 2021 Is anyone here using Texel? I'm trying to create a chart in Texel and could use some help. Suppose I create a list of dates in column A, from 01 Jan 1990 to 10 Jan 1990, with cell A1 being the text string "Date". Suppose I create a list of numbers in column B, between 1 and 2, with cell B1 being the text string "Val1". I select the whole lot of that, click on Insert->Chart, work through the selections, and I can never get the OK button to be enabled. What is the critical step I may be missing? Is my data invalid to start with? Thanks! Quote Link to comment Share on other sites More sharing options...
stokowski Posted March 26, 2021 Share Posted March 26, 2021 Hi, I think, you need also the program "ArtWorx" für graphical output with Texel. It is a very good vector based graphic program and works with texel together. I used this combination under MagiC 20 years ago for my diploma work. Greetings, stokowski Quote Link to comment Share on other sites More sharing options...
