Chr0mak3y Posted March 26, 2021 Share Posted March 26, 2021 Hi there. I am wondering if anyone has one of those old Zydec mice (with the atari/amiga switch on the bottom) like the one in the attached picture. I found one recently that the cable has been broken off. I am trying to figure out the wiring so I can connect a new cable. Does anyone happen to know pcb/cable order. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Chr0mak3y Posted March 26, 2021 Author Share Posted March 26, 2021 The PCB is similar to the one on the left Quote Link to comment Share on other sites More sharing options...
Chr0mak3y Posted March 26, 2021 Author Share Posted March 26, 2021 Oh, and if I match the colors of the wires in the image with the colors of the wires of my replacememt cable, it is wired incorrectly. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted March 26, 2021 Share Posted March 26, 2021 Not sure that that similar mouse has same wire colors for same lines. Usually only 1-2 lines are broken, so you can check with ohmmeter what 9 pin connector pin goes to witch internal connector pin, and color of it's wire. Then, it's easy to find which one goes to GND, and that's almost always black. And then will see which lines are broken. It is almost always near to mouse, so can remove plastic haul of wire and look for exact break(s). Pulling them little helps -usually internal insulation is not broken too, only copper wire self. And then can check to which pin of 9 pin connector it leads. Quote Link to comment Share on other sites More sharing options...
Chr0mak3y Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks for the reply. When i said its cable is broken, i mean it has been pulled off. There is no 9 pin connector, just the bare color wires hanging out Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted March 26, 2021 Share Posted March 26, 2021 I guess that it was rather cut off, after it was not working, then just abandoned. Unfortunately, this is common problem today too, and not only with mouse cables. I have problems with USB cables, USB extenders a lot. And likely main reason is low quality of cables. Atari mouses lasted more. If nobody has cable/connection order, it still can be fixed. For 4 from 8 (9-th pin not used by Atari) can find function, so on what pin on connector - and you can find Atari mouse pinout in 1 sec. That would be GND, +5V and 2 buttons. Remaining 4 can determine by experimenting - only 4x3x2 combinations, in reality less - when one direction works, then only 2 remains. Ah, and just swap 2 if goes in opposite dir. Quote Link to comment Share on other sites More sharing options...
Cubeast Posted March 26, 2021 Share Posted March 26, 2021 Though it may not necessarily be the case I would start with the assumption that the directional wires are in order on the PCB socket. Quote Link to comment Share on other sites More sharing options...
Chr0mak3y Posted March 27, 2021 Author Share Posted March 27, 2021 Thanks for both your replies. I am going to sit down and figure this out tomorrow. I am pretty sure I have sorted out gnd and both buttons. Now for trial and error with the rest Quote Link to comment Share on other sites More sharing options...
