TGB1718 Posted April 27, 2021 Share Posted April 27, 2021 I'm trying to compile some code I wrote bitd using Lattice C V3.03.04, I'm getting a strange error on the link phase:- Undefined Symbol MAIN, all other functions are fine, I get the same result regardless of which file I try to compile/link, I know they have all compiled in the past. So I just wrote the standard "Hello World" program and I still get the same error on the link phase. The only think I can think is different now is I was originally working off floppy drives (possibly!! as I had a Syquest removable drive at one point which unfortunately no longer works) and now I run off a hard drive. It's not complaining about PATH's as I set these in the config file, just the MAIN procedure. Normally you don't define MAIN, but I tried with and without defining it, same result. Has anyone else seen/fixed this error. Quote Link to comment Share on other sites More sharing options...
mellis Posted April 27, 2021 Share Posted April 27, 2021 3 minutes ago, TGB1718 said: I'm trying to compile some code I wrote bitd using Lattice C V3.03.04, I'm getting a strange error on the link phase:- Undefined Symbol MAIN, all other functions are fine, I get the same result regardless of which file I try to compile/link, I know they have all compiled in the past. So I just wrote the standard "Hello World" program and I still get the same error on the link phase. The only think I can think is different now is I was originally working off floppy drives (possibly!! as I had a Syquest removable drive at one point which unfortunately no longer works) and now I run off a hard drive. It's not complaining about PATH's as I set these in the config file, just the MAIN procedure. Normally you don't define MAIN, but I tried with and without defining it, same result. Has anyone else seen/fixed this error. In C, the prototype for main() is: int main(int argc, char** argv); Where argc is the number of command line arguments, and argv is a pointer to an array of char*, where each pointer points to a command line argument. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 27, 2021 Author Share Posted April 27, 2021 Thanks, I should have said I tried all variants of MAIN(), they all fail Quote Link to comment Share on other sites More sharing options...
