tjlazer Posted June 4, 2021 Share Posted June 4, 2021 (edited) Here is a STX file for Bubble Bobble NTSC. The PAL game runs way too slow on NTSC machines for some odd reason. Can someone crack this or make it into a HD install? ParanoidLittleMan? Bubble Bobble (1987)(Taito)[NTSC].zip Edited June 4, 2021 by tjlazer Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 4, 2021 Share Posted June 4, 2021 Here is deprotected ST image of it: BUBON.ZIP Uses usual Rob Norten Copylock 2. Speed problems are because timing, game speed is tied to vertical refresh (not the best way). Hard disk adaptation with cheat will come later (probably combined with PAL version, since most of files are same). And to add: those who have SPC, so can write original with all protection to floppy disks, and have STE will experience something not so pleasant - game will not start. With TOS 1.04 will. So, original is not STE, actually not it's TOS version compatible. So much about 'full copy of original is best, we don't want unreliable cracks" type approach. Image posted here works with TOS 1.62 . Hmm. let see with 2.06 ... 2.06 UK, so PAL - works, Music plays little slower, game speed is not bad, so ideal for those with not so fast fingers ? 2 Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 4, 2021 Share Posted June 4, 2021 I appeared that there is another copy protection, little later. So, ignore above DL, and use this: BUBON.ZIP 1 Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 4, 2021 Share Posted June 4, 2021 Did hard disk adaptation too: http://atari.8bitchip.info/fromhd2.php 1 1 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted June 5, 2021 Share Posted June 5, 2021 Thanks Peter. Quote Link to comment Share on other sites More sharing options...
tjlazer Posted June 5, 2021 Author Share Posted June 5, 2021 Thanks! Quote Link to comment Share on other sites More sharing options...
