ParanoidLittleMan Posted June 6, 2021 Share Posted June 6, 2021 http://www.atarimania.com/game-atari-st-captive_8860.html There are 2 floppies, and not clear what is on second floppy. It's content is same as content of first for some 30 % of capacity, from start. And second floppy starts, then reads floppy to eternity when play screen shows up. Possible bad dump ? Images are same as those in TOSEC, STX section. Just renamed. Any other place where can DL STX images of V 1.2 ? Quote Link to comment Share on other sites More sharing options...
Hellraiser Posted June 6, 2021 Share Posted June 6, 2021 (edited) Don't know if it's v1.2 https://www.oldgames.sk/en/game/captive/download/7523/ https://wowroms.com/P/roms/atari-st/captive-stx/116143.html https://wowroms.com/en/roms/atari-st/captive-stx/116144.html Edited June 6, 2021 by Hellraiser Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted June 6, 2021 Share Posted June 6, 2021 Here is a link to the scp disks of Captive I made from my own disks. Maybe they can help? https://www.dropbox.com/s/hejryxy59c8iawe/[SCP-Atari ST] Captive(Mindscape)(1990)(2d)(5r).7z?dl=1 Quote Link to comment Share on other sites More sharing options...
Mr. Undo Posted June 6, 2021 Share Posted June 6, 2021 2 hours ago, ParanoidLittleMan said: http://www.atarimania.com/game-atari-st-captive_8860.html There are 2 floppies, and not clear what is on second floppy. It's content is same as content of first for some 30 % of capacity, from start. And second floppy starts, then reads floppy to eternity when play screen shows up. Possible bad dump ? Images are same as those in TOSEC, STX section. Just renamed. Any other place where can DL STX images of V 1.2 ? There is a reference to the Atari second disk here: http://captive.atari.org/Main/ReleaseInfo/ReleaseInfo.php "The Atari ST version came with 2 floppy disks even though the second disk is usually not used. The first floppy is a double-sided disk, but in the case where a system is equiped with a floppy drive that only supports single-side floppies, the second disk will be required to read the unreadable side of the first floppy disk. In other words, the second disk is a copy of the second side of the first disk. When the second disk is required, the system will display a request to insert disk two. A way to see it is by removing the floppy disk during the "Federation War" screen (the bouncing lines) and hitting a key." Quote Link to comment Share on other sites More sharing options...
