Randy Posted June 13, 2021 Share Posted June 13, 2021 Ordered what I though would work, it's not even close with many more "tiny" pins on it than the Falcon adapter, not sure what is going on here, any idea what kind of SCSI 2 adapter I can use? Thanks Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 13, 2021 Share Posted June 13, 2021 1 hour ago, Randy said: Ordered what I though would work, it's not even close with many more "tiny" pins on it than the Falcon adapter, not sure what is going on here, any idea what kind of SCSI 2 adapter I can use? Thanks Like this https://www.ebay.com/itm/114521552959?epid=17002497503&hash=item1aaa04383f:g:bloAAOSw8DNfsfxT Or this https://www.ebay.com/itm/402268177745?hash=item5da90d4551:g:MFEAAOSw41pexDIc 1 Quote Link to comment Share on other sites More sharing options...
Randy Posted June 14, 2021 Author Share Posted June 14, 2021 Thanks, the first one does appear to match up with a cable that came with the Falcon of which the other end connects to my Zip drives. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted June 14, 2021 Share Posted June 14, 2021 There are standard SCSI connector types. So, older one for SCSI1 is 50 pins, and it is what is on Falcon (and TT) . Later ones are with 68 pins (and 16 data lines instead 8). Big pin count is because normally every second is GND. Myself made self such 'adapter' instead to pay sometimes enormous prices in my SCSI years. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted June 14, 2021 Share Posted June 14, 2021 Maybe something like this, in my PC I used to have only SCSI drives, got a load of these to connect the drives to the adaptor card. Quote Link to comment Share on other sites More sharing options...
Randy Posted June 14, 2021 Author Share Posted June 14, 2021 15 hours ago, TGB1718 said: Maybe something like this, in my PC I used to have only SCSI drives, got a load of these to connect the drives to the adaptor card. Looks about right, except the Falcon has female connection so the needs a male in. BTW, the TT I have has standard 50-pin SCSI for external... Quote Link to comment Share on other sites More sharing options...
Randy Posted June 14, 2021 Author Share Posted June 14, 2021 15 hours ago, TGB1718 said: Maybe something like this, in my PC I used to have only SCSI drives, got a load of these to connect the drives to the adaptor card. Oops, my bad, I see the male in on the backside by itself, make sense now. I'll look for one of these as well. Quote Link to comment Share on other sites More sharing options...
Randy Posted June 14, 2021 Author Share Posted June 14, 2021 4 minutes ago, Randy said: Oops, my bad, I see the male in on the backside by itself, make sense now. I'll look for one of these as well. Nope, wrong again, this is a 68 pin, not a 50 pin. Quote Link to comment Share on other sites More sharing options...
calimero Posted June 15, 2021 Share Posted June 15, 2021 (edited) On 6/13/2021 at 11:53 PM, Randy said: Ordered what I though would work, it's not even close with many more "tiny" pins on it than the Falcon adapter, not sure what is going on here, any idea what kind of SCSI 2 adapter I can use? Thanks Falcon have external SCSI 2 (50 pin) connector called MD50. Just google it and you will find cables and adapters (I do not know what do you want to cinnect to Falcon...) https://en.m.wikipedia.org/wiki/SCSI_connector btw on this wiki page you will find also info about SCA connector from image from previous post... There are few basic connectors types (I will give name regardless of number of pins): DB (like for mouse, joystick...) Centronics (used on printers...) IDC (used in internals harddisc, floppys, cd-roms...) DIN (used for MIDI, ST monitor connector...) and then there is bunch of less usual types like this MD on Falcon external SCSI port... Edited June 15, 2021 by calimero 1 Quote Link to comment Share on other sites More sharing options...
