www.atarimania.com Posted August 17 Share Posted August 17 On 4/27/2023 at 6:17 PM, SoulBuster said: Sherlock's Hounds (1985)(Swift Clark Marketing)(US)[BASIC][cassette] The size of this program doesn't make sense, do you mind checking again? Thanks! Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 17 Author Share Posted August 17 Which file? I've tested them and they work. Side 1 is longer due to a signature or other recording at the end of the tape. First pic is from the Zip I uploaded (the one you downloaded). The second pic is of the folder on my computer that I uploaded from. 1 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted August 17 Share Posted August 17 3 hours ago, SoulBuster said: I've tested them and they work. Absolutely, they do. It's just weird the .cas file is about 50 times bigger than usual for a program that small. Quote Link to comment Share on other sites More sharing options...
Atarigrub Posted August 17 Share Posted August 17 2 hours ago, www.atarimania.com said: Absolutely, they do. It's just weird the .cas file is about 50 times bigger than usual for a program that small. It probably needs cleaning up. I can do this in a8preservation when I get to this one. I think it's already in the queue there 1 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted August 17 Share Posted August 17 I don't want to derail the thread but wanted to let future people know there are 4 DOS 2.0S images in this thread: Atari 810 Master Diskette II Master Diskette II (1980)(Atari)(US)[disk] Master Diskette II (1983)(Atari)(US)[disk] Master Diskette II (1983)(Atari)(US)[disk] SET2 All have identical binaries. So I personally know for sure we have original content But two pairs of ATRs are identical (a pair of A and a pair of B). It looks like the 1983 disks vs 1980. c3ffae7fda730473571931ee24df067f Master Diskette II (1983)(Atari)(US)[disk] SET2/Master Diskette II.atr c3ffae7fda730473571931ee24df067f Master Diskette II (1983)(Atari)(US)[disk]/Master Diskette II -p 101.atr f3d104b00d1ed9e129d0e10a3e6b4f73 Atari 810 Master Diskette II/Atari 810 Master Diskette II.atr f3d104b00d1ed9e129d0e10a3e6b4f73 Master Diskette II (1980)(Atari)(US)[disk]/Master Diskette II.atr The only difference is hexbyte b40c (04 vs 00): 0000b3f0 ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 |................| 0000b3f0 ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 |................| 0000b400 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 |................| | 0000b400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| 0000b410 42 27 00 04 00 44 4f 53 20 20 20 20 20 53 59 53 |B'...DOS SYS| 0000b410 42 27 00 04 00 44 4f 53 20 20 20 20 20 53 59 53 |B'...DOS SYS| 0000b420 42 2a 00 2b 00 44 55 50 20 20 20 20 20 53 59 53 |B*.+.DUP SYS| 0000b420 42 2a 00 2b 00 44 55 50 20 20 20 20 20 53 59 53 |B*.+.DUP SYS| 0000b430 42 01 00 55 00 41 55 54 4f 52 55 4e 20 53 59 53 |B..U.AUTORUN SYS| 0000b430 42 01 00 55 00 41 55 54 4f 52 55 4e 20 53 59 53 |B..U.AUTORUN SYS| 0000b440 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| 0000b440 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| I'm assuming this is in the unused area of the VTOC (7C). Which is weird. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted August 17 Share Posted August 17 (edited) I'm assuming... That is the problem.... you must know for sure, whether they are untouched or not. Take for example one of the disks and boot it. Put in a new disk, format and write DOS to it. Take a 2nd and do the same. Take the MD5 of both and you discover the MD5s are different! Main thing: the binaries are identical. Edited August 17 by luckybuck Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted August 17 Share Posted August 17 1 hour ago, luckybuck said: I'm assuming... That is the problem.... you must know for sure, whether they are untouched or not. Take for example one of the disks and boot it. Put in a new disk, format and write DOS to it. Take a 2nd and do the same. Take the MD5 of both and you discover the MD5s are different! Main thing: the binaries are identical. Considering the title of this thread, and the fact same person dumped three of the four using the same tools, and all four disks are visibly physically different, I would think they are untouched. Especially since the byte difference is in an unused portion of the VTOC. At first I was suspecting that the tools to make the ATR might have a bug. However, I just found another master (not in this thread) that has that byte as 05. Yes if one formats a disk and installs DOS, and repeats on another disk it will be slightly different in the buffer space that is dumped (if at all) .. but this is an oddball area to have a difference. It's almost like a mastering number. Maybe. I speculate. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted August 18 Share Posted August 18 We will try our very best, as always... more can't be done. There will be unanswered questions, that is very sad, but that's the way it is... Quote Link to comment Share on other sites More sharing options...
Atarigrub Posted August 19 Share Posted August 19 (edited) On 8/17/2024 at 7:24 PM, Atarigrub said: It probably needs cleaning up. I can do this in a8preservation when I get to this one. I think it's already in the queue there I've checked and found I'd already recently processed this, but its awaiting Archiving on a8preservation. Here's the cleaned CAS file (16.4kb). Program is identical between sides, so only one CAS required. The extra audio at the end of side A, is someone turning on a microphone, so no actual program data there. SherlocksHounds.cas Edited August 19 by Atarigrub 3 2 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted August 19 Share Posted August 19 Thanks to all of you! Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 24 Author Share Posted August 24 On 8/17/2024 at 4:19 AM, www.atarimania.com said: The size of this program doesn't make sense, do you mind checking again? Thanks! @www.atarimania.com I think I know why. I have been saving a newly created WAVs from Altirra. It seems that when Altirra saves a CAS directly from a WAV you get larger files. I just did a Silent Service Cassette (man that damn thing is almost 19 minutes of load time) and the file that Altirra made was 500k+. When I used a wav2cas program It came out at 63k. Then I used Altirra to clean the CAS up, saved it out, and it was about the same size as the wav2cas program made it. I say "a wav2cas program" because I do not know which it is or where I got it and it does not identify itself. 2 Quote Link to comment Share on other sites More sharing options...
www.atarimania.com Posted August 24 Share Posted August 24 44 minutes ago, SoulBuster said: I think I know why. Thanks for the explanation! 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 Auto-Term (-)(SWP)(US)[disk] ATR8000 Auto-Term (-)(SWP)(US)[disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 DiskDef II (1985-01-15)(SWP)(US)[CPM][disk] Untested. ATR8000 DiskDef II (1985-01-15)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 CPM Update with Hard Drive Disk Utilities (1985-10-24)(SWP)(US)[CPM][DISK] Untested. ATR8000 CPM Update with Hard Drive Disk Utilities (1985-10-24)(SWP)(US)[CPM][DISK].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 Modem Source Code (-)(SWP)(US)[CPM][disk] Untested. ATR8000 Modem Source Code (-)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 AutoTerm 80 (-)(SWP)(US)[CPM][disk] Untested. ATR8000 AutoTerm 80 (-)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 BIOS Source Code (1984-04-27)(SWP)(US)[CPM][disk] Untested. ATR8000 BIOS Source Code (1984-04-27)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 MS-DOS TM V2.11 for Co-Power-88 (-)(SWP)(US)[CPM][disk] Untested. ATR8000 MS-DOS TM V2.11 for Co-Power-88 (-)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 MSDOS v2.11 Load File and Ramdisk Software (1984-07-03)(SWP)US)[CPM][disk] Untested. ATR8000 MSDOS v2.11 Load File and Ramdisk Software (1984-07-03)(SWP)US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 ROM Source Code v3.02 (-)(SWP)(US)[CPM][disk] Untested. ATR8000 ROM Source Code v3.02 (-)(SWP)(US)[CPM][disk].zip 5 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 ATR8000 SysDisk - CPM v2.2 (1984-04)(SWP)(US)[CPM][disk] Untested. ATR8000 SysDisk - CPM v2.2 (1984-04)(SWP)(US)[CPM][disk].zip 6 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 Atari User Vol 1 No 8 (1985-12)(Atari User)(GB)[disk] Still has bad sectors, all in an unused part of the disk. Atari User Vol 1 No 8 (1985-12)(Atari User)(GB)[disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 Atari User Vol 1 No 9 (1986-01)(Atari User)(GB)[disk] Atari User Vol 1 No 9 (1986-01)(Atari User)(GB)[disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted August 27 Author Share Posted August 27 Atari User Ten of the Best Games (-)(Atari User)(GB)[disk] Atari User Ten of the Best Games (-)(Atari User)(GB)[disk].zip 4 Quote Link to comment Share on other sites More sharing options...
