Heaven/TQA Posted August 17, 2003 Share Posted August 17, 2003 did somebody managed to run this emulator? everytime i make adjustments on the settings the emulators quits... i want to test how accurate it is... hve Quote Link to comment Share on other sites More sharing options...
classics Posted August 17, 2003 Share Posted August 17, 2003 did somebody managed to run this emulator? everytime i make adjustments on the settings the emulators quits... i want to test how accurate it is... hve I had the same problem. Start the emulator and save a configuration file using the configuration save option, then restart the emulator and it should start to work. This was on windows btw. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted August 17, 2003 Author Share Posted August 17, 2003 ok... useful hint... after saving the prefs you need to edit the config file and enter the paths + filename of the OS roms... that's all... thanks! now let's check how good the beast is... hve Quote Link to comment Share on other sites More sharing options...
