Gitbizy Posted January 28, 2022 Share Posted January 28, 2022 I received my Side3 a few weeks ago, and I am trying to figure out how to get the RTC to work with Spartados X 4.49. Inside the loader, the date and time are correct, but when I do CTRL-X and go to Spartados, and do date/time the values are the "Default" values for spartados X. When I look at CAR: config.sys, there is a side3.sys in there, but no side3clk.sys My "boot" drive is D3:, which is an APT partition on the Side3. There is no config.sys on D3. There is an autoexec.bat but no references to Side3 / RTC. When I look at the CAR: directory under spartados, there is a file side3clk.sys but I cannot copy it to D3. What is the proper way to setup/use the RTC so that spartados can get the correct date/time from the Side3 RTC? Thanks! Quote Link to comment Share on other sites More sharing options...
BillC Posted January 29, 2022 Share Posted January 29, 2022 6 hours ago, Gitbizy said: I received my Side3 a few weeks ago, and I am trying to figure out how to get the RTC to work with Spartados X 4.49. Inside the loader, the date and time are correct, but when I do CTRL-X and go to Spartados, and do date/time the values are the "Default" values for spartados X. When I look at CAR: config.sys, there is a side3.sys in there, but no side3clk.sys My "boot" drive is D3:, which is an APT partition on the Side3. There is no config.sys on D3. There is an autoexec.bat but no references to Side3 / RTC.++ When I look at the CAR: directory under spartados, there is a file side3clk.sys but I cannot copy it to D3. What is the proper way to setup/use the RTC so that spartados can get the correct date/time from the Side3 RTC? Thanks! The CAR: device only has 1 buffer which is insufficient for copying files, the post linked below has a workaround using the TYPE command. Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 (edited) 10 minutes ago, BillC said: The CAR: device only has 1 buffer which is insufficient for copying files, the post linked below has a workaround using the TYPE command. Thanks, I will try that. how do I make spartados use the config.sys file on the d3: (c) drive instead of using the one on CAR:? I’m presuming you suggest that I copy the side3clk.says to d3: and then put that file in config.says on d3? Edited January 29, 2022 by Gitbizy Quote Link to comment Share on other sites More sharing options...
BillC Posted January 29, 2022 Share Posted January 29, 2022 (edited) 18 minutes ago, Gitbizy said: Thanks, I will try that. how do I make spartados use the config.sys file on the d3: (c) drive instead of using the one on CAR:? I’m presuming you suggest that I copy the side3clk.says to d3: and then put that file in config.says on d3? I don't know if you actually need to move the side3clk.sys to D3:, try just editing your config.sys on D3: to use CAR:side3clk.sys. DEVICE CAR:SIDE3CLK.SYS Edited January 29, 2022 by BillC Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 1 hour ago, BillC said: I don't know if you actually need to move the side3clk.sys to D3:, try just editing your config.sys on D3: to use CAR:side3clk.sys. DEVICE CAR:SIDE3CLK.SYS I don’t have a config sys on D3 but I will put one there and try your recommendation above. Will report back soon. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 29, 2022 Share Posted January 29, 2022 You can also put your own config.sys on your spartados x image... Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 20 minutes ago, _The Doctor__ said: You can also put your own config.sys on your spartados x image... Doc can you point me to directions on that? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 29, 2022 Share Posted January 29, 2022 http://sdx.atari8.info/index.php?show=en_addons while you are there you can download just about everything you need... pre-made or to roll your own... in this case you want to check out the imager.... Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted January 29, 2022 Share Posted January 29, 2022 (edited) 3 hours ago, Gitbizy said: I don’t have a config sys on D3 but I will put one there and try your recommendation above. Will report back soon. You should - please read chapter 8.3 in the user guide to see what can be achieved. For most users there is not really a need to change anything in the CONFIG.SYS on the CAR device. Nearly everything can be managed by a .SYS in the subdirectory SPARTA.DOS on the boot medium. It offers up to 19 choices to be placed there for a customized CONFIG.SYS. Besides, the driver is already noted in the CONFIG.SYS on SIDE3. See attached screenshot. Edited January 29, 2022 by GoodByteXL error 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted January 29, 2022 Share Posted January 29, 2022 Here's a config.sys residing on my boot drive:- Works fine for me across Side2 and SIDE3 D9:>TYPE CONFIG.SYS DEVICE SPARTA OSRAM DEVICE SIO DEVICE ATARIDOS DEVICE ULTIME ; This is the clock driver DEVICE JIFFY DEVICE FATFS DEVICE D9:\PCLINK.SYS ; DEVICE DOSKEY D9:ALIASES.INI DEVICE DOSKEY SET PATH=CAR:;D6:\BIN\;D5:\BAT\;D9: SET MANPATH=D6:\MAN\ The DOSKEY for using ALIASES is commented out as I found it to be a bit buggy I also use an AUTOEXEC.BAT, nothing to do with the clock, but sets my system to my preferences. D9:>TYPE AUTOEXEC.BAT D5: SET BASIC=DN:BASIC.SAV SET SCRDEF=2,141,0,0 SET PROMPT=D$N$P> QUICKED.SYS ECHO "" ECHO "DRIVES:-" ECHO "D5: D6: D7: D8: D9:" ECHO "DJ: DK: DL: DM: FAT=DO:" Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 @TGB1718 thank you very much! Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 Is there a link to how to update the spartadosX on the Side3? I have searched google unsuccessfully. I downloaded the brand new 4.49g and put all The files on a fat32 drive and put it in the side3 but how do I get the side3 to update its CAR to 4.49g? Quote Link to comment Share on other sites More sharing options...
DrVenkman Posted January 29, 2022 Share Posted January 29, 2022 15 minutes ago, Gitbizy said: Is there a link to how to update the spartadosX on the Side3? I have searched google unsuccessfully. I downloaded the brand new 4.49g and put all The files on a fat32 drive and put it in the side3 but how do I get the side3 to update its CAR to 4.49g? The latest beta downloads are here: http://sdx.atari8.info/index.php?show=en_download_beta Be absolutely sure to download only the correct version for your hardware (there are a LOT of choices)! Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 19 minutes ago, DrVenkman said: The latest beta downloads are here: http://sdx.atari8.info/index.php?show=en_download_beta Be absolutely sure to download only the correct version for your hardware (there are a LOT of choices)! I did download those but I do not know how to get them to "flash" on top of the current SIDE3 CAR: rom Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 29, 2022 Share Posted January 29, 2022 4 minutes ago, Gitbizy said: I did download those but I do not know how to get them to "flash" on top of the current SIDE3 CAR: rom There should be an ATR which you can mount on your SIO2xxx device. Boot the machine into SDX (on the SIDE3), then either type 'COLD /N' to boot the ATR, or run the flashing tool at the DOS prompt. 1 Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 3 minutes ago, flashjazzcat said: There should be an ATR which you can mount on your SIO2xxx device. Boot the machine into SDX (on the SIDE3), then either type 'COLD /N' to boot the ATR, or run the flashing tool at the DOS prompt. Thanks FJC. I hate to presume, but is the flashing tool (utility) on that ATR partition? Thank you all for your patience. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 29, 2022 Share Posted January 29, 2022 As mentioned, it is much easier to simply create a directory named sparta.dos on your boot drive and place alternate config.sys files there. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 29, 2022 Share Posted January 29, 2022 Just now, Gitbizy said: I hate to presume, but is the flashing tool (utility) on that ATR partition? Absolutely, yes. DLT generally make the flashing tool auto-boot if the system is booted with SDX disabled. It's usually called 'S3FLASH.COM' or similar. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 29, 2022 Share Posted January 29, 2022 1 minute ago, Stephen said: As mentioned, it is much easier to simply create a directory named sparta.dos on your boot drive and place alternate config.sys files there. This won't work with the SIDE cartridges unless the machine has U1MB PBI support, though, since on 'stand alone' cart setups, the CONFIG.SYS on the CAR: device is responsible for loading the HDD driver which provides access to the hard disk. I believe the 'MERGE' command can be employed on U1MB-less setups, but I haven't had occasion to look into it. If the user has U1MB, of course, the SPARTA.DOS folder works just fine. 1 Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Author Share Posted January 29, 2022 Thank you all - going to give this a whirl today. You all have been very helpful. Quote Link to comment Share on other sites More sharing options...
BillC Posted January 29, 2022 Share Posted January 29, 2022 (edited) 12 hours ago, TGB1718 said: DEVICE ULTIME ; This is the clock driver That is the clock driver for the U1MB, DEVICE SIDE3CLK is the driver to use for the SIDE3 standalone(no U1MB installed). @Gitbizy I don't have a SIDE3 but do have the original SIDE. I added a SIDE3 device in Altirra 4.0 and flashed the correct SDX 4.49G to it, after a TD ON(and a RESET because it didn't display, maybe a bug in Altirra?) the current time/date is displayed in SDX. Edited January 29, 2022 by BillC 2 Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 30, 2022 Author Share Posted January 30, 2022 (edited) Update: downloaded the 4.49g Side3 image using my sio2sd v2, I mounted the ATR booted up Did a directory on the 4.49g and there was flasher.com ran flasher.com rebooted 4.49g now has the latest Side3 drivers - base side3 and also side3clk preconfigured in config.sys - right out of the box so now my RTC works perfectly! thanks my Atari friends for all your help and input. Edited January 30, 2022 by Gitbizy 2 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted July 22, 2023 Share Posted July 22, 2023 Is there a way to upgrade SpartaDOS-X on a SIDE3 without being able to mount the ATR and/or having a U1MB? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 22, 2023 Share Posted July 22, 2023 3 minutes ago, reifsnyderb said: Is there a way to upgrade SpartaDOS-X on a SIDE3 without being able to mount the ATR and/or having a U1MB? No, but if you want a stand-alone XEX flasher you can run directly from the loader (just as you would when upgrading the loader itself), let me know and I'll see if I can put one together. 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted July 22, 2023 Share Posted July 22, 2023 56 minutes ago, flashjazzcat said: No, but if you want a stand-alone XEX flasher you can run directly from the loader (just as you would when upgrading the loader itself), let me know and I'll see if I can put one together. If I understand correctly, I will be able to copy the XEX flasher (and SpartaDOSX ROM image) onto the SD card, insert the SD card into the the SIDE3, run the XEX flasher, and upgrade SpartaDOSX? This would be great and a big help to those of use who have the SIDE3 cartridge but don't have a way to mount the ATR. Thanks! Is this a case of either converting an already existing program or adding a new feature to the program? Quote Link to comment Share on other sites More sharing options...
