atrax27407 Posted January 29, 2022 Share Posted January 29, 2022 Does a program exist (or is it possible to write one) to import and extract the files contained in a .dsk file directly on the TI? 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted January 29, 2022 Share Posted January 29, 2022 9 minutes ago, atrax27407 said: Does a program exist (or is it possible to write one) to import and extract the files contained in a .dsk file directly on the TI? Do you have a TIPI as I use TIDir to do this directly from PC to TI using the TIPI and a mapped network drive. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 29, 2022 Author Share Posted January 29, 2022 My current process is to use TIDir and take the resultant 3.5" disk, turn around in my swivel chair, and run PC-TRANSFER to move them to my TI. I was hoping that there might be a program written on the TI, that would import the .dsk file to the TI and extract the files. Probably too much to ask. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 29, 2022 Share Posted January 29, 2022 Do you have a TIPI as I use TIDir to do this directly from PC to TI using the TIPI and a mapped network drive.You know that's kind of silly when you can just copy the disk file to the TIPI drive and it will automatically unpack it to a folder. Named the name of the diskSent from my Pixel 6 Pro using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted January 29, 2022 Share Posted January 29, 2022 The disk backup program on the DU2K disk I got (apparently) does this. I have not tested it with a DSK image made off the TI, but it should work as the formats are identical (less the extra 1k or 2k of zeros when creating an image.) 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 29, 2022 Author Share Posted January 29, 2022 Thanks. Quote Link to comment Share on other sites More sharing options...
RXB Posted January 29, 2022 Share Posted January 29, 2022 2 hours ago, arcadeshopper said: You know that's kind of silly when you can just copy the disk file to the TIPI drive and it will automatically unpack it to a folder. Named the name of the disk Sent from my Pixel 6 Pro using Tapatalk This gets corrupted sometimes. TIDir does not have that issue plus I can open and look at files unlike normal file from Windows will not open files like a XB program but TIDir will. Plus Windows does not allow you to view files from PC like XB or Object files or DV80 or GRAM files. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 30, 2022 Share Posted January 30, 2022 1 hour ago, RXB said: This gets corrupted sometimes. TIDir does not have that issue plus I can open and look at files unlike normal file from Windows will not open files like a XB program but TIDir will. Plus Windows does not allow you to view files from PC like XB or Object files or DV80 or GRAM files. - if you have this happen please post the disk image in the tipi support forum so we can figure out why. - I've had tidir make changes to filenames that made the program unusable until I went in and renamed everything manually..telco is a good example Greg 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted January 30, 2022 Share Posted January 30, 2022 6 minutes ago, arcadeshopper said: - if you have this happen please post the disk image in the tipi support forum so we can figure out why. - I've had tidir make changes to filenames that made the program unusable until I went in and renamed everything manually..telco is a good example Greg Yea ran into this bug caused by filename in TIDir, and asked why it needs two names. Example a bug I hate is making all files lower case when the filename was ALL UPPPER CASE! 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 31, 2022 Share Posted January 31, 2022 Yea ran into this bug caused by filename in TIDir, and asked why it needs two names. Example a bug I hate is making all files lower case when the filename was ALL UPPPER CASE!The case sensitive nature of Linux makes that matter.. the unpacker in TIPI uses the case of the original files in the disk image tho.. so unless someone's used lower case in the filenames they are usually all UPPERCASESent from my Pixel 6 Pro using Tapatalk Quote Link to comment Share on other sites More sharing options...
