mutantcamel1979 Posted February 14, 2022 Share Posted February 14, 2022 (edited) I have just ordered a 32K Expansion and I am looking for the correct 5V power supply to use with it and the Speech Synthesizer. I have a Pifco multi adapter with various plugs. One is 2.1 x 5mm. Would this work? I also have a 2.5 x 5.5mm plug. The Brewing Academy lists it as 5.5 x 2.1mm. I have bought the unit from elsewhere, otherwise I would have bought an adapter from them! I live in the UK, so if anyone could point me in a direction of a decent adapter, then that would be appreciated! I do not want to fry my machine or equipment over the sake of a few pounds! Thanks Edited February 14, 2022 by mutantcamel1979 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted February 14, 2022 Share Posted February 14, 2022 Probably the 2.1 x 5mm will contact well enough. With multi-adapter make sure it is "tip positive" , the inside part of the plug is the +5v, the outside is GND https://www.jedimatt42.com/ti32kmem.html Quote Link to comment Share on other sites More sharing options...
Stuart Posted February 14, 2022 Share Posted February 14, 2022 Using a multi-adaptor may be asking for trouble .. when you change the voltage to use with something else then forget to change it back! I'd suggest either getting a fixed-voltage adaptor with a suitable plug, or google "usb to barrel connector" and get a connector to plug into a USB charger. (Whereabout in the UK are you?) 2 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 14, 2022 Author Share Posted February 14, 2022 (edited) If the 32K Expansion doesn't have a power light I will be paranoid that my multi adapter is not powering it, if the jack is slightly the wrong size! Thanks - Regarding the usb to barrel connector, there is no mention if the tip is positive or negative. I live in Yorkshire. Edited February 14, 2022 by mutantcamel1979 Quote Link to comment Share on other sites More sharing options...
Stuart Posted February 14, 2022 Share Posted February 14, 2022 Centre (tip) positive tends to be the standard ... although of course you do need to check. https://shop.pimoroni.com/products/barrel-jack-adapter-usb-to-5-5mm says its centre positive ... 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted February 15, 2022 Share Posted February 15, 2022 There is no power light on my 32k card design. There is an activity light. When the 4A is off, the led state is undefined. My sense is that it usually 'floats' such that the light is on. Then when you turn the 4A on, the led turns off, cause the 4A doesn't use it until some particular software actually uses it. 1 Quote Link to comment Share on other sites More sharing options...
