macsonny Posted April 6, 2022 Share Posted April 6, 2022 Hi All, Just scored a Megafile 30. It has an issue where sometimes it powers on but the hard drive doesn't startup. If it's turned off, left for a few mins and turned back on it works fine. Would this likely be a hard drive "sticking" or failing, or a power supply issue? Also, anyone know where I can get the pin-out to make a cable to go between the Megafile 30 and my STFM? Thanks Sonny Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 6, 2022 Share Posted April 6, 2022 I would check the PSU voltages first and hopefully that's the problem. If not then I would suspect the drive is on it's way out. Attached is a document for the pinout. You need to source 2 x 19 pin D plugs, I've never managed to source any, maybe someone here knows different. If you do make a cable, make sure it's good quality with shielding. ST ACSI Timing.pdf Quote Link to comment Share on other sites More sharing options...
snarkdluG Posted April 6, 2022 Share Posted April 6, 2022 ...or hack a db25 and order some PCB. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 6, 2022 Share Posted April 6, 2022 12 minutes ago, snarkdluG said: ...or hack a db25 and order some PCB. Yup, done that, got the tee-shirt Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted April 6, 2022 Share Posted April 6, 2022 Best Electronics has 3ft ACSI cables for $15 https://www.best-electronics-ca.com/cables.htm Quote Link to comment Share on other sites More sharing options...
mickster Posted April 6, 2022 Share Posted April 6, 2022 3 hours ago, macsonny said: Hi All, Just scored a Megafile 30. It has an issue where sometimes it powers on but the hard drive doesn't startup. If it's turned off, left for a few mins and turned back on it works fine. Would this likely be a hard drive "sticking" or failing, or a power supply issue? Also, anyone know where I can get the pin-out to make a cable to go between the Megafile 30 and my STFM? Thanks Sonny I have one that has the exact same symptoms. I haven't looked into it yet. Quote Link to comment Share on other sites More sharing options...
macsonny Posted April 17, 2022 Author Share Posted April 17, 2022 So it looks like the Atari ST <-> MegaFile cable sis just PIN 1 <-> PIN 1 all the way through to PIN 19 <-> PIN 19 right? Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 17, 2022 Share Posted April 17, 2022 Yes, this confirms it, very useful site for all cables https://info-coach.fr/atari/hardware/interfaces.php Quote Link to comment Share on other sites More sharing options...
