fabrice montupet Posted April 13, 2022 Share Posted April 13, 2022 Is there a way to modify the pattern & color of the character 31, just using the SCRN1 in XB256 (not SCRN2), with a subroutine like CALL LINK("VWRITE",...) ? Thank you for any help. Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted April 13, 2022 Share Posted April 13, 2022 Sure, yeah, you can be a very naughty boy and redefine stuff like XB's cursor character (that's 30, though) if you like, by writing data straight to VDP. That being said, you of course can't VWRITE the hex string you'd feed to CALL CHAR. You have to VWRITE the appropriate binary data. Which will likely itself contain unprintable characters, which you cannot type in BASIC (but could read from a file, or insert into a BASIC program with a hex editor, or just obtain from a series of CHR$ calls). So for example, this will make your cursor a hash sign: CALL LINK("VWRITE",1009,"((|(|((") Pointless! But...uh...neat, I guess? As I say though, that was 30, and 31 is thus CALL LINK("VWRITE",1017,"((|(|((") Or whatever other data you want to use. "((|(|((" is just a 7/8ths of a character pattern which is all printable characters, treated as ASCII. Hence my using that. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted April 14, 2022 Share Posted April 14, 2022 Following up on what pixelpedant wrote, the following program defines char 32 as a box, reads the data you just wrote (the character pattern for 32 is at 1024), writes it to the pattern for char 31 to 1016, then clears the pattern for space: 10 CALL CHAR(32,"FF818181818181FF"):: CALL LINK("VREAD",1024,8,A$):: CALL LINK("VWRITE",1016,A$):: CALL CHAR(32,"0") 20 GOTO 20 If you used a different character such as 129 then you wouldn't necessarily have to redefine it. Another way would be like this: 10 FOR I=1 TO 8 :: READ N :: A$=A$&CHR$(N):: NEXT I :: CALL LINK("VWRITE",1016,A$) 20 GOTO 20 30 DATA 255,129,129,129,129,129,129,255 Both these methods are cumbersome for redefining characters. RXB and XB 2.9 G.E.M. are able to use CALL CHAR to define characters from 30 to 159, so either of these might be an option. If you intend to compile your program, you can use XB 2.9 G.E.M. or RXB for testing. When you compile there is no error checking so the problem goes away. 2 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 14, 2022 Share Posted April 14, 2022 By using the user interrupt, it's possible to make a cursor that inverts the character it's on top of. Quote Link to comment Share on other sites More sharing options...
SteveB Posted April 14, 2022 Share Posted April 14, 2022 18 hours ago, pixelpedant said: That being said, you of course can't VWRITE the hex string you'd feed to CALL CHAR. You have to VWRITE the appropriate binary data. Which will likely itself contain unprintable characters, which you cannot type in BASIC (but could read from a file, or insert into a BASIC program with a hex editor, or just obtain from a series of CHR$ calls). Currently in testing for the next TiCodEd release is a "function" BIN$("hex") which will substitute the hex-string with the binary "octect-string" when tokenizing, so only for static hex-strings: A$=BIN$("A0002AB5") for i=1 to 4 print val(seg$(a$,i,1) next i Very much designed for the use of CALL VWRITE. We had this discussion recently on a Saturday-Call and it seems to work... But be careful when editing on the TI. 1 Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted April 14, 2022 Author Share Posted April 14, 2022 Thank you all for your answers ? I used the 1st senior_falcon method, it's perfect. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 14, 2022 Share Posted April 14, 2022 Just for the fun of it did this in RXB: 10 CALL CHAR(32,"FF818181818181FF") :: CALL MOVES("V$",8,1024,A$,"$V",8,A$,1016) :: CALL CHAR(32,"0") 20 GOTO 20 And: 10 FOR I=1 TO 8 :: READ N :: A$=A$&CHR$(N) :: NEXT I :: CALL MOVES("$V",8,A$,1016) 20 GOTO 20 30 DATA 255,129,129,129,129,129,129,255 And I thought of another way to accomplish same thing: 10 CALL CHAR(32,"FF818181818181FF") :: CALL SWAPCHAR(32,31) 20 GOTO 20 Sorry just so many ways to attack same problem. 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 14, 2022 Share Posted April 14, 2022 14 hours ago, apersson850 said: By using the user interrupt, it's possible to make a cursor that inverts the character it's on top of. Can't think of why you would need the interrupt to do that. Couldn't the code that waits for a key and flashes the cursor do that inside its own loop? (Of course now I have to make one ) Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted April 15, 2022 Share Posted April 15, 2022 I'm pretty sure apersson was talking about the cursor used in XB. To change that you'd either have to modify the cartridge, or use an interrupt routine to do the job. I thought about doing this for XB 2.9 G.E.M., but it seemed like more trouble than it was worth. If you are writing your own editor, then of course no interrupt routine would be required. 1 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 15, 2022 Share Posted April 15, 2022 3 hours ago, senior_falcon said: I'm pretty sure apersson was talking about the cursor used in XB. To change that you'd either have to modify the cartridge, or use an interrupt routine to do the job. I thought about doing this for XB 2.9 G.E.M., but it seemed like more trouble than it was worth. If you are writing your own editor, then of course no interrupt routine would be required. You can change the Cursor in XB in 2.9 and RXB. In case you want to see the GPL routine that switches CURSOR with what ever character it is over: *---------------------------------------------------------- * Auto-repeat function is added for 99/4A, in PSCANS line * READ00 to READZ2+1 are changed to following code *---------------------------------------------------------- READ00 CLR @PAD Counter for auto-repeat fucti * * To get out of insert mode, we usually return here. * READ01 CLR @ARG8 Indicate normal operation mod ST CURSOR,@PAD1 Use PAD1 for CURSOR/CHARACTER * Idicate one character and alternate current character * position between normal and cursor. READZ1 EX @PAD1,V*ARG5 By alternating between the * normal character and the * cursor, we make the cursor CLR @TIMER blink G6AAE CALL DUSER USER from EDIT mode BS READZ2 Found one!!!! G6AB3 INC @PAD Increment the auto-repeat cou CEQ >FF,@RKEY It is an old key BS G6AC5 CHE >FE,@PAD Hold old key for a while BR G6AC5 SUB 30,@PAD Control repeat rate B READZ5 G6AC5 CH >10,@TIMER Time next character switch BR G6AAE BR READZ1 Restart character blink cycle 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 15, 2022 Share Posted April 15, 2022 Yes, I was talking about the cursor in TI Extended BASIC. And I was not talking about changing the shape of the cursor from what it is (a block) to something else (an underline), but to change it to the inverse video of the character it's covering. I've done that once. The purpose was to show if you were in insert of overwrite mode when editing a text, by having a different cursor behavior. 2 1 Quote Link to comment Share on other sites More sharing options...
