johnph3 Posted April 19, 2022 Share Posted April 19, 2022 I recently acquired a Corcomp 9900 disk controller card for the PEB. Looks to be modified for it has a daughter board with a WD1773 28 pin controller chip plugged into the original 40 pin socket on the main board. My question is what was original 40 pin controller chip and can I replace the daughter board with the correct 40 pin chip? Thanks for your help Quote Link to comment Share on other sites More sharing options...
+dhe Posted April 19, 2022 Share Posted April 19, 2022 Pictures would be great. The is a thread here not to long ago which I think applies to your board. The original chip used in the corcomp was very buggy, the daughter-board is an engineering fix for reliability. Is the unit working? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 19, 2022 Share Posted April 19, 2022 Corcomp FDC with WD1773 and with WD2793 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted April 19, 2022 Share Posted April 19, 2022 The board you have is the original revision of the CorComp DSDD controller. It was designed for the WD2793 controller chip. Unfortunately, at the time CorComp started production on them, a huge number of defective WD2793 chips were released into the distribution channel by the manufacturer. The defect was due to a process error at the factory. The defective chips affected a lot of OEMs at the time, as the 2793 was a pretty popular chip. There was a serious uproar about it in the tech media at the time. Some chips produced at that time were good, but something like 90% of them from the affected lots were bad. CorComp tested their on-hand stock and fitted the good ones into as many of the disk controllers from the first run as they could. There weren't anywhere near enough good chips though, so they built the daughter boards with the software-compatible WD1773 on them and finished the run. To avoid a repeat of the problem, the boards were redesigned to use the WD1773 from that point on. If the board you bought was the one recently sold on eBay, I believe it even included a letter from CorComp that somewhat explains what they did (a clean scan of that letter would be a good thing to add to our online documentation repository too). Your DSDD controller with the daughter board is actually seriously uncommon, so you may want to keep it as it is. 1 Quote Link to comment Share on other sites More sharing options...
johnph3 Posted April 19, 2022 Author Share Posted April 19, 2022 so mine looks like bottom production board except instead of 40 pin chip it has this daughter board with wd1773 on it. So my question is is there any other mods done to the main board to allow the daughter board to work. The daughter board is built on a 40 pin plug that plugs directly onto the main board 40 pin socket. I read about the issue at the time, but I was wondering if I came across a new version of the WD2793 which is what I believe is original could I substitute it without any reverse modification? Just like to play you know. 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 19, 2022 Share Posted April 19, 2022 I have one of those with a working 2793 controller. Quote Link to comment Share on other sites More sharing options...
johnph3 Posted April 19, 2022 Author Share Posted April 19, 2022 It is working in it's current configuration. So you might wonder why I want to mess with it? Because I can, I like to play and see if I can get it to work as originally designed. Strange thing I have noticed going between it and my ti floppy controller is the ti controller doesn't recognize the disk I formatted with the CorComp controller not even the single density ones. However the Corcomp seems to functiopn properly, haven't had any trouble formatting disk single density or double density and it reads back fine. I did however burn a couple of upgrade proms for it to get rid of corcomp's annoying opening screen. 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 19, 2022 Share Posted April 19, 2022 55 minutes ago, johnph3 said: It is working in it's current configuration. So you might wonder why I want to mess with it? Because I can, I like to play and see if I can get it to work as originally designed. Strange thing I have noticed going between it and my ti floppy controller is the ti controller doesn't recognize the disk I formatted with the CorComp controller not even the single density ones. However the Corcomp seems to functiopn properly, haven't had any trouble formatting disk single density or double density and it reads back fine. I did however burn a couple of upgrade proms for it to get rid of corcomp's annoying opening screen. it also won't read a disk formatted dsdd with my corcomp controller right? maybe some sort of issue with either your drive or that controller Greg Quote Link to comment Share on other sites More sharing options...
johnph3 Posted April 19, 2022 Author Share Posted April 19, 2022 This my Corcomp 9900 card. IT is working and is capable of formatting double density disk and reading from them. And I have tried three different 5 1/4 inch half height drives A teac fd235 and a panasonic JU-475. The other one however is not double density but these two are. Same issue reading the tunnels of doom disk. I don't know why. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted April 19, 2022 Share Posted April 19, 2022 FWIW, Unicorn Electronics has 2793 disk controller chips for $14.99. Their stuff is really good. 1 Quote Link to comment Share on other sites More sharing options...
johnph3 Posted April 20, 2022 Author Share Posted April 20, 2022 23 hours ago, arcadeshopper said: it also won't read a disk formatted dsdd with my corcomp controller right? maybe some sort of issue with either your drive or that controller Greg It reads the header and catalogs part of contents but not all of it Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 20, 2022 Share Posted April 20, 2022 14 minutes ago, johnph3 said: It reads the header and catalogs part of contents but not all of it sounds a lot like it's not reading side 2. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 21, 2022 Share Posted April 21, 2022 If you have the Disk Manager cartridge or some other disk manager tool, try to do a sector read over all sectors of the disk (simple test). Note the first sector that is unreadable. For instance, when there is a problem with the second side, you should be able to read sectors 0-719 of a DSDD disk, but sectors 720-1439 are unreadable. Quote Link to comment Share on other sites More sharing options...
