rietveld Posted May 5, 2022 Share Posted May 5, 2022 Paid $13 (after using a $2 off coupon) for this LaserJet printer with a full toner cartridge 3 Quote Link to comment Share on other sites More sharing options...
rietveld Posted May 7, 2022 Author Share Posted May 7, 2022 I built a a stand for the LaserJet printer but the Adam still takes up a lot of space. The h89 on the right is my 80 column display for the Adam 1 Quote Link to comment Share on other sites More sharing options...
christo930 Posted May 11, 2022 Share Posted May 11, 2022 Back around 2002 or 2003 I bought a Lasterjet printer from a flea market, also for $15. I paid another 17 Dollars for an Ethernet and Apple Talk cards (which adds PDF printing). Been using it ever since. Still on the same toner cartridge. The best thing about it is as a networked printer, I keep it in the basement and powered off unless I need to print in which case I turn it on. Printers take up so much room and are unsightly. You can print to it from basically anything. Mac classic, Mac OS X, Amiga, DOS, Windows, Atari ST etc. Even though I primarily use it through Ethernet, it has a parallel port on it for things like Amiga and DOS. Would probably work with an Adam with a Adam to parallel port adapter, same with other 8 bits. 2 Quote Link to comment Share on other sites More sharing options...
