+dhe Posted May 12, 2022 Share Posted May 12, 2022 I purchased a copy of TI Toad from the bay. The seller was perfectly honest, the cartridge had lost it's label in the past. The quality of labels and their adhesives seem to have varied greatly amongst vendors. Does anyone have a photo of a TI Toad label? What's your go to for making labels? ie.. is there an Avery stock that works particularly well? A particular type of printer? 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 12, 2022 Share Posted May 12, 2022 (edited) for TI TOAD I have found a pair of kind of labels and I do not know the history of them: this one for the top/front (I do not like so much this kind of labels) and this classic ones front labels (I prefer them) I should have the original one and I can work on the label if needed to print. as the printer, I am not an expert and with my laser printer at home I only create the test labels. Then I prefer to print them using a plotter in a professional printer service. Edited May 12, 2022 by ti99iuc 3 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 12, 2022 Share Posted May 12, 2022 The bottom one is the early version of the DBT label, Ciro. The top one is what they went to later on. Those later ones really had issues sticking to the cartridge, so Dan's was probably one of those (but the early version would still be a better choice). 4 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 13, 2022 Author Share Posted May 13, 2022 Ciro - what stock do you have the plotter print upon? Do you use a photo to start with or re-do the whole graphic? FWIW - The top label looks as if it might have been printed from one of the TI's package - maybe PagePro? That only rings a bell, because in the 90's - many TI User Group newsletters where produced with PagePro and the selection of font's - while different looking - don't do so well with scan to text software (at all). 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 13, 2022 Share Posted May 13, 2022 the professional printer service that I use for print the label using the glossy adesive paper and the print is an Hires inkjet. example of a WIP plotter printer for the Super Astrosmash stickers: I already created lot of labels so I just take an image of one I already created and works on it in photoshop. The easier ones are the classic black style to create. For new styles of labels I need to re-do the whole graphic every time. Photoshop also really help to restoring a good scan from the original labels. The hard part could be to find the right fonts but internet bynow really help in doing this. about Pagepro it is possible that in origin it was created with it, anyway In all the ones I have it appears like a bad photocopied label ? 41 minutes ago, dhe said: That only rings a bell, because in the 90's - many TI User Group newsletters where produced with PagePro and the selection of font's - while different looking - don't do so well with scan to text software (at all). I absolutely agree, it is sad also in the case of the actual newsletter created by @sparkdrummer , Yesterday News, could be nice to have a recognized search text for it but very hard with that font. 1 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 22, 2022 Share Posted May 22, 2022 Do we have a label thread on here somewhere? If not, we should start one, including tips such as manufacturers, image files, etc. 3 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 22, 2022 Share Posted May 22, 2022 (edited) @dhe hope this can help TI-TOAD Label.pdf Edited May 22, 2022 by ti99iuc 4 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 22, 2022 Share Posted May 22, 2022 9 hours ago, acadiel said: Do we have a label thread on here somewhere? If not, we should start one, including tips such as manufacturers, image files, etc. There is one. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 22, 2022 Share Posted May 22, 2022 @dhe I done a try also for the late version label so you can use the one you prefer at least ? TITOAD_Databiotics_Label_v2.pdf 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 22, 2022 Author Share Posted May 22, 2022 https://atariage.com/forums/topic/278311-label-creation/?tab=comments#comment-4018782 -and- 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 22, 2022 Author Share Posted May 22, 2022 Tony mentioned stickeryou.com. Anyone have current experience with what options to choose? Tony did mention the correct size was: 3.62 x 0.56" This is a sticker, kiss cut, it acted like I could change the size, but didn't! ? Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 22, 2022 Share Posted May 22, 2022 (edited) I have never used an online service, but be sure to consider the cut lines in the corners. maybe you could need one with a white background for that kiss cut service because I really doubt for their precision in the cut. Edited May 22, 2022 by ti99iuc Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 23, 2022 Share Posted May 23, 2022 On Sticker You, I use them all the time. You can make your graphic grow--and it is stronly advisable that the blank parts of the graphic extend beyond the black line. You make the graphic change size by clicking on it and pulling on the lower right corner until the things you want to print fill the green cut lined area. Doing it this way keeps the graphic in proportion, and then you can move it around to center it as needed. Ciro's last, solid white label is actually perfect here, as it lets you center the text and ignore everything else. Quote Link to comment Share on other sites More sharing options...
digdugnate Posted May 23, 2022 Share Posted May 23, 2022 I left this browser tab up so I would remember to take a look at my TI Toad cart. This is pertinent to my interests. 2 Quote Link to comment Share on other sites More sharing options...
digdugnate Posted May 23, 2022 Share Posted May 23, 2022 Mine's actually in pretty good shape! 1 Quote Link to comment Share on other sites More sharing options...
PeBo Posted May 24, 2022 Share Posted May 24, 2022 On 5/12/2022 at 6:01 PM, dhe said: I purchased a copy of TI Toad from the bay. The seller was perfectly honest, the cartridge had lost it's label in the past. The quality of labels and their adhesives seem to have varied greatly amongst vendors. Does anyone have a photo of a TI Toad label? What's your go to for making labels? ie.. is there an Avery stock that works particularly well? A particular type of printer? If you have the manual, DBT carts usually used the same font on their labels and manuals. My Micro Tennis came in a beige cart with a full square fold-over label that looked generated by a dot-matrix printer. I managed to open the cart without destroying the label, and created a more standard spine label for a replacement black cart to match the rest of my DBT collection (I'm anal that way). I did keep the original cart and label though, so I didn't worry about authenticity on my label. If I ever sell it, I'll swap it back into the original cart. Strangely, my Space Patrol came with a black label with white text. The only other variation I've seen from DBT's black text on white, was Junkman Junior's red on white, so I've always wondered if my Space Patrol's label is the original. (My Micro Pinball II has a Micro Pinball label, so not sure is that's a replacement or a misprint like Protector.) 4 Quote Link to comment Share on other sites More sharing options...
digdugnate Posted May 24, 2022 Share Posted May 24, 2022 7 minutes ago, PeBo said: If you have the manual, DBT carts usually used the same font on their labels and manuals. My Micro Tennis came in a beige cart with a full square fold-over label that looked generated by a dot-matrix printer. I managed to open the cart without destroying the label, and created a more standard spine label for a replacement black cart to match the rest of my DBT collection (I'm anal that way). I did keep the original cart and label though, so I didn't worry about authenticity on my label. If I ever sell it, I'll swap it back into the original cart. Strangely, my Space Patrol came with a black label with white text. The only other variation I've seen from DBT's black text on white, was Junkman Junior's red on white, so I've always wondered if my Space Patrol's label is the original. (My Micro Pinball II has a Micro Pinball label, so not sure is that's a replacement or a misprint like Protector.) Good to see you around, old friend! I was going to say that with my collection, once it gets into my hands it very seldom leaves. ?Life sentence! Quote Link to comment Share on other sites More sharing options...
PeBo Posted May 24, 2022 Share Posted May 24, 2022 3 minutes ago, digdugnate said: Good to see you around, old friend! I was going to say that with my collection, once it gets into my hands it very seldom leaves. ?Life sentence! Same here, but I'm sure the family members that survive me will do whatever is necessary to maximize profits from my estate. So maybe I kept the original cart/label for them. And thank you sir...was inevitable that I would visit, now that I am living the good life (retirement) (I have a tipi/sams I need to learn how to use, and a PEB who's fan is in desperate need of replacing (although it does provide a realistic propellor sound effects when playing Spad XIII)) atariage continues to be the best source for such things. (and certainly more reliable than my geriatric brain) 2 Quote Link to comment Share on other sites More sharing options...
