Bill R Sullivan Posted June 11, 2022 Share Posted June 11, 2022 My F18A Ti-99/4A USB device has failed. It looks okay and provides a "BEEP" along with the TI title screen, and then an immediate "HONK", but it is necessary to unplug the USB cable in order to use the TI-99/4A keyboard. I'm also aware that it has a second USB port, but is intended for some other purpose, as it has a different connector. Is this the usual failure for this USB device? It is also very difficult for me to open up the TI console to this degree, and then close it back up without messing something else up! RetroBill (fdos) Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 11, 2022 Share Posted June 11, 2022 You mentioned the keyboard, so you must be talking about the TI 99 USB Keys adapter, and not the USB PEB card... or maybe you are using Fred's USB keyboard adapter? I haven't ever heard of any failures of any of the different keyboard adapters. But I have only heard of Shift838 and Arcadeshopper using my adapter design... 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 11, 2022 Share Posted June 11, 2022 (edited) Pretty sure he got it from me.. Is there power the teensy? leds on? if so Either there's a failure on the teensy OR it needs to be reflashed you can plug in a micro usb cable into the teensy and use the arduino teensy tool to reflash it.. instructions are here: https://jedimatt42.com/ti99usbkeys.html under loading the firmware.. this will be a good test if the teensy is alive or not as well @9640News try this too Edited June 11, 2022 by arcadeshopper 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted June 12, 2022 Share Posted June 12, 2022 11 hours ago, Bill R Sullivan said: My F18A Ti-99/4A USB device has failed. It looks okay and provides a "BEEP" along with the TI title screen, and then an immediate "HONK", but it is necessary to unplug the USB cable in order to use the TI-99/4A keyboard. I'm also aware that it has a second USB port, but is intended for some other purpose, as it has a different connector. Is this the usual failure for this USB device? It is also very difficult for me to open up the TI console to this degree, and then close it back up without messing something else up! RetroBill (fdos) make sure your Alpha Lock key is not engaged if using the USB keyboard. Quote Link to comment Share on other sites More sharing options...
Bill R Sullivan Posted June 13, 2022 Author Share Posted June 13, 2022 On 6/11/2022 at 8:53 AM, jedimatt42 said: You mentioned the keyboard, so you must be talking about the TI 99 USB Keys adapter, and not the USB PEB card... or maybe you are using Fred's USB keyboard adapter? I haven't ever heard of any failures of any of the different keyboard adapters. But I have only heard of Shift838 and Arcadeshopper using my adapter design... I do believe it is yours, as it has the second USB port that may be able to restore operation, but I don't have the instructions for using it. Quote Link to comment Share on other sites More sharing options...
Bill R Sullivan Posted June 13, 2022 Author Share Posted June 13, 2022 On 6/11/2022 at 1:09 PM, arcadeshopper said: Pretty sure he got it from me.. Is there power the teensy? leds on? if so Either there's a failure on the teensy OR it needs to be reflashed you can plug in a micro usb cable into the teensy and use the arduino teensy tool to reflash it.. instructions are here: https://jedimatt42.com/ti99usbkeys.html under loading the firmware.. this will be a good test if the teensy is alive or not as well @9640News try this too Thanks, I believe the instructions will do the trick, as the standard USB port does power the 4 port K/V/M when my TI console is the only unit powered. Quote Link to comment Share on other sites More sharing options...
Bill R Sullivan Posted June 13, 2022 Author Share Posted June 13, 2022 On 6/11/2022 at 7:21 PM, Shift838 said: make sure your Alpha Lock key is not engaged if using the USB keyboard. Of course, as the PC keyboard Caps Lock does the trick for both when it's working! Quote Link to comment Share on other sites More sharing options...
