The MilkMan Posted September 16, 2003 Share Posted September 16, 2003 So I'm going along, I've gotten all the traffic to stop at this point...I go inside porkys, get the detonator device ( or push it rather into the hole on the bottom) climb up and out, reach the blue screen with scafolding. But I can't go all the way up. I climb about 4 levels up the scafolding and can go no more. He just set there vibrating...I either climb down or fall off. Also, I notice a red arrow pointing down on the right side ( also on or about the 4th level of scafolding) now what do I do? Quote Link to comment Share on other sites More sharing options...
moycon Posted September 16, 2003 Share Posted September 16, 2003 You need to take the correct route up the scafolding. If you see a red arrow...It means you took the wrong route...Follow the green arrows up to the top...And then BOOOOOM!!!! Quote Link to comment Share on other sites More sharing options...
Gregory DG Posted September 16, 2003 Share Posted September 16, 2003 Wow... You can get THAT far? I can't even get out of the friggin' hole... Quote Link to comment Share on other sites More sharing options...
The MilkMan Posted September 16, 2003 Author Share Posted September 16, 2003 You need to take the correct route up the scafolding. If you see a red arrow...It means you took the wrong route...Follow the green arrows up to the top...And then BOOOOOM!!!! AAHHH HAA! I knew that arrow was for something! Cool! Thanks dude! Quote Link to comment Share on other sites More sharing options...
The MilkMan Posted September 16, 2003 Author Share Posted September 16, 2003 Wow... You can get THAT far? I can't even get out of the friggin' hole... you have to "pole vault" out of there. Grab the pole by holding the button, and let go of button half way accross, you'll fly up to the ledge above. Then you have to grab a "step" that floats on the ledge. Grab it 4 times and build the ladder to exit to the top. Quote Link to comment Share on other sites More sharing options...
