Ricky Spanish Posted August 28, 2022 Share Posted August 28, 2022 So we can dump the computers OS, yet, can't upload them the same way, so how does the ATARI TRANSLATOR DISK upload the 400/800 OS to our XL computers? I know it blocks the factory OS and places the 400/800 OS into ram. But that's all I know. Asking cause I think it would be nice just to upload an OS without having to buy different hardware / replace chips etc. Thanks. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 28, 2022 Share Posted August 28, 2022 It would need to load the OS into low RAM so no need to access the disk via OS during the install, then switch out the OS and copy the replacement OS up to the correct location. Did something similar for a printer driver, copied the OS to RAM, switch out the OS, copy the OS back to RAM, make changes to the OS now resident in RAM, printer driver with no extra RAM usage 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 28, 2022 Share Posted August 28, 2022 You can copy the OS to Ram and modify it in place. Or have one you load from disk to replace the stock OS. Running an OS from RAM has the risk of being overwritten. Translator OS I believe does have some modifications though minor. You need a code stub in lower Ram so that your replacement OS survives a warmstart (reset). Modifications needed to the OS would be such things as making sure the top of memory test doesn't exceed address $BFFF. For testing purposes it's handy to be able to load a different OS. But in the real world you'd still want one on switchable flash or Eprom. 1 Quote Link to comment Share on other sites More sharing options...
ACML Posted August 28, 2022 Share Posted August 28, 2022 If you want to directly load the Atari 400/800 OSa or OSb or Omniview 80 OS, try these: Atari XL to OSB Translators.ATR Omnivew 80 Disk Version.atr Rev-A OS.xex Rev-B OS.xex XL to 800 Emulator.xex 2 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted August 28, 2022 Author Share Posted August 28, 2022 55 minutes ago, ACML said: If you want to directly load the Atari 400/800 OSa or OSb or Omniview 80 OS, try these: Actually I want to place 1200xl rev11 OS into my 1200xl. But I'm sure those are very useful for those that need it ! Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 29, 2022 Share Posted August 29, 2022 Something I forgot - with the XL OS you'd have a hard time with Self-Test and possibly the 1200XL rainbow logo. The switchable part that loads at $5000 is right in the middle of main Ram, so having that reside there isn't very practical. I suppose in lieu of BYE you could probably have it as a loadable binary file. 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted October 25, 2022 Author Share Posted October 25, 2022 On 8/28/2022 at 8:15 PM, Rybags said: Something I forgot - with the XL OS you'd have a hard time with Self-Test and possibly the 1200XL rainbow logo. The switchable part that loads at $5000 is right in the middle of main Ram, so having that reside there isn't very practical. I suppose in lieu of BYE you could probably have it as a loadable binary file. Is rev 10 and rev 11 that much different ? AFAIK all the memory locals are the same. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 26, 2022 Share Posted October 26, 2022 1 hour ago, Ricky Spanish said: Is rev 10 and rev 11 that much different ? AFAIK all the memory locals are the same. In my limited tests, rev 11 is more compatible than rev 10 with some earlier 400/800 software. Had the 1200XL not been canceled so abruptly it would have undoubtedly become the standard. It's not that hard at all to put into real hardware with a pair of 8Kb EEPROMs and a little bit of minimal hardware work if necessary to reconfigure some motherboard jumpers. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted October 26, 2022 Author Share Posted October 26, 2022 14 minutes ago, DrVenkman said: In my limited tests, rev 11 is more compatible than rev 10 with some earlier 400/800 software. Had the 1200XL not been canceled so abruptly it would have undoubtedly become the standard. It's not that hard at all to put into real hardware with a pair of 8Kb EEPROMs and a little bit of minimal hardware work if necessary to reconfigure some motherboard jumpers. Did you make those ? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 26, 2022 Share Posted October 26, 2022 1 minute ago, Ricky Spanish said: Did you make those ? The two EPROMs? Yep. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted October 26, 2022 Author Share Posted October 26, 2022 38 minutes ago, DrVenkman said: The two EPROMs? Yep. You willing to make a couple more ? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 26, 2022 Share Posted October 26, 2022 9 minutes ago, Ricky Spanish said: You willing to make a couple more ? Unfortunately I don't think I have any more compatible EPROMs. And mailing them to Canada would be probably be more expensive than it's worth, lol. I expect there's got to be someone around here who can use domestic Canada Post for you. There's a whole thread around here from two-three years ago that has the details on how to do the conversion. It's a lot simpler if your 1200XL came from the factory with EPROMs already, which some did. All three of mine came with mask ROMs though, so I didn't have that luck. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted October 26, 2022 Author Share Posted October 26, 2022 3 minutes ago, DrVenkman said: Unfortunately I don't think I have any more compatible EPROMs. And mailing them to Canada would be probably be more expensive than it's worth, lol. Everything I bought cames outta the states lol. The 256k DRAMs / Sdrive Max / UAV / 256 RAMBO. Except for my Hercules cables. Even then I still had to pay USD haha. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted October 27, 2022 Share Posted October 27, 2022 From kr0tki’s documents on every OS version: “ Rev. 11 was developed by Robert Scott Scheiman,[38], and it fixed several problems of the previous revision with function of the Reset key.[29] The order of routines was also changed, apparently to fit in a few unofficial OS vectors for better compatibility with programs designed for the 400/800 OS revisions. The most noticeable difference is in the power-up display - in rev. 11 an ® mark was added to the Atari logo. ” Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted October 27, 2022 Author Share Posted October 27, 2022 7 minutes ago, kheller2 said: and it fixed several problems of the previous revision with function of the Reset key. What's the problem the RESET key ? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 28, 2022 Share Posted November 28, 2022 the 1200xl had some reset issues that I believe bob1200xl or was it? that addressed hardware issue for the reset circuits and timing (cap? chip?) and the rev 11 OS addressed the issues as best it could in the firmware (OS ROM/prom) Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 28, 2022 Share Posted November 28, 2022 From a quick look - Rev 10 doesn't have the soft delay loop on cold/warmstart. The delay exists in all future OS releases and I would say the reason is as a Reset key debounce. There is s short time where the OS clears Page 3 which contains the magic number sequence indicating the machine has already had a coldstart. If those numbers aren't present the OS assumes a coldstart is required. A bouncing key or the user pressing Reset twice with the right timing can cause a (usually unwanted) coldstart. With practice I was able to generate a coldstart this way on my 800XL probably better than 1 in 10 attempts. I guess without this delay it could have been a problem on the machines with that OS revision. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 28, 2022 Share Posted November 28, 2022 sounds about right. Quote Link to comment Share on other sites More sharing options...
