Ricky Spanish Posted September 4, 2022 Share Posted September 4, 2022 Anybody got it working in spartados 3.x (disk version)? If so, how ? I kinda got it working in spartados 1.x but the LOADING 4.11 EXTENSIONS splash screen hangs after it finishes loading & I need to press [RESET] to get rid of it. As always, thanks. Quote Link to comment Share on other sites More sharing options...
BillC Posted September 4, 2022 Share Posted September 4, 2022 4 hours ago, Ricky Spanish said: Anybody got it working in spartados 3.x (disk version)? If so, how ? I kinda got it working in spartados 1.x but the LOADING 4.11 EXTENSIONS splash screen hangs after it finishes loading & I need to press [RESET] to get rid of it. As always, thanks. SpartaDOS 1.x/2.x aren't compatible, SpartaDOS 3.2 was developed for compatiblity with BASIC XE. I have also tested that it works with SpartaDOS X v4.49 in Altirra 4.0. Quote Link to comment Share on other sites More sharing options...
Mrshoujo Posted September 4, 2022 Share Posted September 4, 2022 Do you have extended RAM? Like a RAMbo XL 256k? That's where the BASIC XE extensions load. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 4, 2022 Share Posted September 4, 2022 (edited) As Mrshoujo said, you need at least an XL/XE with 128KB RAM (no 400/800 with Axlon) for BASIC XE. These work for me: Sparta32D-BXE41.atr BASIC XE v4.1 (1985)(OSS)(US)[!].car Edited September 4, 2022 by DjayBee Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 4, 2022 Author Share Posted September 4, 2022 2 hours ago, Mrshoujo said: That's where the BASIC XE extensions load. Well with extensions disk you also get a bunch of new commands like BSAVE, CALL, DEL, EXIT, FAST, LOCAL, LVAR, MOVE, PROCEDURE, RENUM, RGET, RPUT, SORTUP, SORTDOWN, the fast math routines, and all P/M commands except HITCLR. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 4, 2022 Author Share Posted September 4, 2022 (edited) 2 hours ago, DjayBee said: These work for me: Hey thanks for that. But with real hardware (XL anyways) going from basic to dos back to basic locks up the computer. Edited September 4, 2022 by Ricky Spanish Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 4, 2022 Author Share Posted September 4, 2022 crashes with Altirra under these specs as well; Base system NTSC 1200XL Additional devices 1050 disk drive (full emulation) OS firmware Atari 1200XL OS rev. 10 [C5C11546] Mounted images Disk: Sparta32D-BXE41.atr [ECD93310] Cartridge: OSS BASIC XE 4.1.car [7A6EB0A3] Quote Link to comment Share on other sites More sharing options...
Alfred Posted September 5, 2022 Share Posted September 5, 2022 Create a STARTUP.BAT file and put the line KEY OFF in it to disable the keyboard buffer in 3.2. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 5, 2022 Author Share Posted September 5, 2022 (edited) 4 hours ago, Alfred said: Create a STARTUP.BAT file and put the line KEY OFF in it to disable the keyboard buffer in 3.2. At the risk of me sounding stupid, how do I do that ? Looked in the directory and it has AUTOBAT.COM. Not the same I take it ? Edited September 5, 2022 by Ricky Spanish Quote Link to comment Share on other sites More sharing options...
Mrshoujo Posted September 5, 2022 Share Posted September 5, 2022 (edited) Load up a word processor like TextPro. Type KEY OFF[cr] And save it as STARTUP.BAT in the root directory of the boot disk. Basically, any word processor program which works under SpartaDOS and saves straight text files works for this. Also don't use the 1200XL OS for this BASIC XE / SpartaDOS combination. I should get more familiar with Altirra's options but you want to be using the OS for the 600XL/800XL. I don't know if that's OS Rev.B or whatever it's referred to. I believe the 400/800 OS is called REV. A anyway. I do know the 1200XL OS is a whole different incompatible beast. Edited September 5, 2022 by Mrshoujo Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 5, 2022 Author Share Posted September 5, 2022 6 minutes ago, Mrshoujo said: Basically, any word processor program which works under SpartaDOS and saves straight text files works for this. Can that be done with Atariwriter ? Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 5, 2022 Share Posted September 5, 2022 12 hours ago, Ricky Spanish said: At the risk of me sounding stupid, how do I do that ? Looked in the directory and it has AUTOBAT.COM. Not the same I take it ? Do it from BASIC: 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 5, 2022 Author Share Posted September 5, 2022 46 minutes ago, DjayBee said: Do it from BASIC: Well same thing happens; Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 5, 2022 Share Posted September 5, 2022 (edited) 28 minutes ago, Ricky Spanish said: Well same thing happens; My comment was not meant as a solution to your problem but only on how to create the autostart file. But, that said: The problem lies in the way how MENU does RunCar. This happens in EMulation and as 800XL in the same manner. If you select Exit followed by CAR, the Atari does not crash. Since MENU uses a lot of RAM, your BASIC program will be deleted after returning from MENU. Edited September 5, 2022 by DjayBee 1 Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted September 5, 2022 Author Share Posted September 5, 2022 15 minutes ago, DjayBee said: If you select Exit followed by CAR, the Atari does not crash. Worked like a charm ! Many thanks ! Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted November 1, 2022 Author Share Posted November 1, 2022 Little update : Decided to give this another shot with the 256k RAMBO w/ real hardware (previously only using DOS 2.5). Everything works as advertised, no need for startup.bat or any exiting techniques . Wonder why it was a problem with 64K but not with 256K? Quote Link to comment Share on other sites More sharing options...
spookt Posted November 1, 2022 Share Posted November 1, 2022 Have a feeling you need extended memory for the extensions. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted November 2, 2022 Author Share Posted November 2, 2022 2 hours ago, spookt said: Have a feeling you need extended memory for the extensions. That's a distinct possibility, however with DOS 2.5 it does not, which is perplexing. Quote Link to comment Share on other sites More sharing options...
spookt Posted November 2, 2022 Share Posted November 2, 2022 SpartaDOS will most likely use more RAM than DOS 2.5. Quote Link to comment Share on other sites More sharing options...
Ricky Spanish Posted November 2, 2022 Author Share Posted November 2, 2022 15 hours ago, spookt said: SpartaDOS will most likely use more RAM than DOS 2.5. So curiosity killed that cat so-to-speak & I checked, there's actually more free memory [FRE(0)] with Sparta. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2022 Share Posted November 22, 2022 BASIC XE does like itself some Xtra ram like on the 130XE that's for sure. It like to control that xtra ram itself too. Quote Link to comment Share on other sites More sharing options...
