TGB1718 Posted September 18, 2022 Share Posted September 18, 2022 I've just upgraded to Windows 11 (someone had to ) Loads of stuff missing, slowly getting it sorted, one thing, Altirra settings have gone and I'm trying to set it up as I had it before. If I try to add U1M in Devices by clicking "Add" there is no entry for U1M to add. If I select Firmware Manager" I have set Ultimate 1MB to point to U1MBS3FW.ROM If I enable Use U1M it won't boot, I also tried the default Altirra U1MB, same result. Un-tick Use U1M and it will boot off an ATR in drive 1 I had this all working before, I just can't remember how it looked or how I set it up before. I thought Altirra used a config file, but can't find one Anyone advise what I'm doing wrong/missing (probably will kick myself when I find out) I have SIDE3 installed ok pointing to my SSD image drive. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 18, 2022 Share Posted September 18, 2022 (edited) Don't forget, U1MB is added in the memory settings.. And by default Altirra uses the registry, its only if you set to portable that you get the config.. Edited September 18, 2022 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 18, 2022 Share Posted September 18, 2022 (edited) @TGB1718This is one of the reasons I keep holding back upgrading to 11 - despite the nagging auto prompt in my sys tray to do so the past 6months or so. I have had this before between OS upgrades. There is no config folder as such I can see either. Edited September 18, 2022 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 18, 2022 Share Posted September 18, 2022 The main reason I won't come off Win 10 is that I'm told that 11 needs quite a powerful set of resources, something that this ageing Dell does not have.. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 18, 2022 Author Share Posted September 18, 2022 I had to upgrade due to constant "blue screen of death", nothing I did could resolve the problem, so I went daft and upgraded my old (8-9 year old system) for a nice new motherboard/cpu/memory, so Windows 11 sort of came with the whole upgrade. I did the upgrade to Win 11 from 10, but it brought the BS of D with it, so this morning a clean install got most things running as I want them, but watch out for "ONE DRIVE" it screwed up everything by moving all my files and programs off my hard drive to OneDrive and it broke everything, all my desktop icons flew into the cloud and all my documents too, I thought it just made a copy , what a stupid piece of software 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 18, 2022 Share Posted September 18, 2022 (edited) Yep, win 10 does the One drive thing, it even remaps the blooming my documents shortcut to it.. I went to delete some emulation data and could not bloody find it, after a search vis Opus it said it was in a one drive folder... PS, I was getting a constant BSOD, turned out to be my USB drivers...Drove me insane.. Hopefully you got the U1mb going Edited September 18, 2022 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 18, 2022 Author Share Posted September 18, 2022 (edited) Not got it going, It's when I enable it in the Memory settings it hangs. I think I need to try find what U1M firmware I used and point at that It's here somewhere Update: found the firmware I had saved, made it default and bingo, all working 🤩 Edited September 18, 2022 by TGB1718 Update 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 18, 2022 Share Posted September 18, 2022 As you've perhaps realised, U1MBS3FW.ROM is a 64K file to be flashed to the 'firmware' slot using UFLASH. Altirra needs to have the entire 512K ROM image attached to it (so, ULTIMATE.ROM, UTLNOGOS.ROM, or - in your case - U1MBS3.ROM). Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 18, 2022 Author Share Posted September 18, 2022 11 minutes ago, flashjazzcat said: As you've perhaps realised DOH!!! Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 20, 2022 Author Share Posted September 20, 2022 Sort of got it going, but still some issues U1m boots, but will not run my config.sys which is on D9: I have set the boot device to be D9: and config.sys on D9:. I have an Autoexec.bat on that partition too and that runs fine. My U1m BIOS is Version 4.05 and SIDE3 is Version 0.44. I boot to SDX fine, I can see all my partitions except the FAT partition. As config.sys does not run, I can manually type PCLINK.SYS and the PCL: device works do the same for FATFS and it still doesn't work. On the loader menu I can browse the AFT partition and see all the .ATR's and .XEX files on there. FDISK also see's the FAT partition. So I need to resolve why CONFIG.SYS doesn't run and why I can't access the FAT partition Warning again about ONE DRIVE (again), I mapped a folder to drive D4: on my desktop by clicking on the desktop icon in the browse folder option, Freaking Windows 11 was pointing at the One Drive->desktop folder, the penny only dropped when I copied a new set of flash files onto the desktop folder and they didn't appear in the browser. I just need a way to get rid of One Drive, it's a Microsoft Virus of the worst kind. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 20, 2022 Share Posted September 20, 2022 Turn off 'fast boot' in acceleration settings if you haven't already done so. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 20, 2022 Share Posted September 20, 2022 So I guess if you can't load the config.sys which points to installing the Fatfs.sys file that would allow you to read/see the FAT partition on SDx, why then manually loading FATFS.sys in SDx doesn't work? Wonder if as FJC suggests with Fast boot off it'll load config.sys? I hate one-drive too. Never use it. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 20, 2022 Author Share Posted September 20, 2022 (edited) 40 minutes ago, flashjazzcat said: Turn off 'fast boot' in acceleration settings if you haven't already done so. That fixed it, thanks very much, didn't think I would have had issues with this as all my "Atari" stuff is on another drive which shouldn't have been affected by installing Windows 11. The only saving grace is that I've had no BSOD's since the clean install. I also found out you can uninstall One Drive, did it and it's gone (forever) Edited September 20, 2022 by TGB1718 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 20, 2022 Share Posted September 20, 2022 1 minute ago, TGB1718 said: I also found out you can uninstall One Drive, did it and it's gone (forever) 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 20, 2022 Author Share Posted September 20, 2022 I bet Micro$oft will find a way to re-install it 👎🏾 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 20, 2022 Share Posted September 20, 2022 What happens with OneDrive? It's been sitting in QuickAccess in all explorer Windows for years. I've never bothered it, and it's never bothered me. Quote Link to comment Share on other sites More sharing options...
