stushug Posted October 19, 2022 Share Posted October 19, 2022 I just purchased a 410 from ebay. The belts were all very stretched so I bought the 4 belt kit from Console5. After changing the belts I noticed the deck still didn't work in play. I found a rather deep scar on the drive tire for play. Anyone know a source for replacement tires? I know the deck only plays when the computer tells it to, and that part is working. The motor comes on when it's supposed to, the problem seems to be isolated to this worn tire. I uploaded pictures for reference. The spindle circled in green is the one I pulled the bad tire from. The scar is circled in teal. Quote Link to comment Share on other sites More sharing options...
stushug Posted November 7, 2022 Author Share Posted November 7, 2022 I found something that I think may work. The site is: https://fixyouraudio.com/ I removed the tire and measured the diameter of the spindle itself and my new measurements are ID 11.7mm x OD 19mm x Thickness 2.4mm They have a tire that is 11.8mm x 19mm x 2.0mm. I think that will work. I can let you know when I get them or you can order your own now. They are located in Europe so it may take a while to receive them. Quote Link to comment Share on other sites More sharing options...
stushug Posted November 18, 2022 Author Share Posted November 18, 2022 The tires from https://fixyouraudio.com/ arrived today and I installed them in my two 410's. They work perfectly. See pic for part number and description. 1 Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted November 18, 2022 Share Posted November 18, 2022 I did something much simpler. I bought a washer, in a plumber's store. 1/2" external diameter, if I remember correctly. The ones that are used often in kitchen sink water taps. Fits perfectly and so it works. 1 Quote Link to comment Share on other sites More sharing options...
mutterminder Posted February 2, 2023 Share Posted February 2, 2023 On 11/17/2022 at 4:46 PM, stushug said: The tires from https://fixyouraudio.com/ arrived today and I installed them in my two 410's. They work perfectly. See pic for part number and description. Thanks for the the link. I've been looking for these a long time. I just order 4 of them. They look like they have lots of parts, maybe I'll try to fix my old TEAC cassette recorder too. Quote Link to comment Share on other sites More sharing options...
BillC Posted February 2, 2023 Share Posted February 2, 2023 On 11/17/2022 at 4:46 PM, stushug said: The tires from https://fixyouraudio.com/ arrived today and I installed them in my two 410's. They work perfectly. See pic for part number and description. Just remember to leave the PLAY and PAUSE buttons pressed when the 410 isn't being used and you shouldn't have to replace the tire again. 1 Quote Link to comment Share on other sites More sharing options...
stushug Posted February 2, 2023 Author Share Posted February 2, 2023 2 hours ago, mutterminder said: Thanks for the the link. I've been looking for these a long time. I just order 4 of them. They look like they have lots of parts, maybe I'll try to fix my old TEAC cassette recorder too. The people on this site have helped me countless times. It's nice to be able give something back for a change! I hope they work out for you. 1 Quote Link to comment Share on other sites More sharing options...
Vyvyan B. Posted February 2, 2023 Share Posted February 2, 2023 I repaired one of these a while back, there is another oddly shaped idler underneath the mechanism that you cannot see without taking it all apart, like a dogbone, but round. That one had flat spots in it too. Had to make a new one by hand. Quote Link to comment Share on other sites More sharing options...
