dipdoodle Posted 3 hours ago Share Posted 3 hours ago 7 hours ago, mitsurugi-w said: Yeah the adapter doesnt work with the power base converter for the same reason a version of this adapter can't be made for Japanese consoles. Cost-cutting measures by sega. Again it's not a flaw in the product. It's just impossible because the Genesis doesn't support all necessary signals. Actually we (I) said earlier in this thread the Japan mk-2000 sms would/should work via the expansion connector. You just need an adapter that goes from expansion connector to export cartridge connector and it should work. Japan exp port is exactly the same as the export one, and the export one is exact the same pins as the export sms has It's only the mark 3 that doesn't have the right pins at all Quote Link to comment Share on other sites More sharing options...
mitsurugi-w Posted 2 hours ago Share Posted 2 hours ago I'm unfamiliar with this adapter. Does it exist? Quote Link to comment Share on other sites More sharing options...
dipdoodle Posted 2 hours ago Share Posted 2 hours ago Yes. I built one and use it to make an internal Everdrive mod. Here is a guide https://www.smspower.org/maxim/uploads/Documents/SMS-Gender-Adapter-v3.png Quote Link to comment Share on other sites More sharing options...
dipdoodle Posted 2 hours ago Share Posted 2 hours ago On 4/11/2024 at 1:28 AM, Apocalypse said: @Dire 51, @dipdoodle is right, an adapter on the expansion port will work. On 4/10/2024 at 7:40 PM, dipdoodle said: Sign me up please! In Europe If you build one of these I bet it will work. The expansion bus is the exact same for Japanese sms and export sms, and the expansion bus pinout is simply an inverted mirror of the export cartridge pinout. Quote Link to comment Share on other sites More sharing options...
