TGB1718 Posted November 16, 2022 Share Posted November 16, 2022 I was trying to copy files I had backed up in Altirra to my 800 (Incognito) I had D3: in Respeqt as PCL3: so changed directory to PLC3\D5 ; D5 is a backup of partition 5 DPCL3:\D5>COPY /B /R *.* D5:\ It starts to copy the files as expected but as soon as it hits a directory (BASIC):- BASIC> 150 Path not found DPCL1:\D5> I checked I had the latest Incognito/SDX installed, so I did the same thing on my 130XE U1M/SIDE3 and it failed in the same way as soon as it hit the BASIC directory. I thought it might be something to do with Respeqt so I tried in Altirra (PCL1:) DPCL1:\D5>COPY /B /R *.* D5:\ BASIC> 150 Path not found DPCL1:\D5> exactly the same. However if I change directory to D5: and type COPY /B /R PCL3:\D5\*.* D5: It works Quote Link to comment Share on other sites More sharing options...
phaeron Posted November 16, 2022 Share Posted November 16, 2022 There are bugs in the SDX COPY /R command with device names longer than one character: 3 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 17, 2022 Author Share Posted November 17, 2022 12 hours ago, phaeron said: There are bugs in the SDX COPY /R command with device names longer than one character: Thank you @phaeron , at least even with the bug, you can copy using the last method I used. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2022 Share Posted November 22, 2022 I don't remember it showing as DPCL3 but rather PCL3 could that also be an issue? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 22, 2022 Share Posted November 22, 2022 oddly all other devices stay at 3 plus 1 dskx etc. but d is concatenated to pclx this seems like a mistake as it's 4 char plus 1 instead of 3 plus 1 @trub @drac030 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 23, 2022 Share Posted November 23, 2022 add that with the copy command bug chopping off 1 or 2 and... well, not great... Quote Link to comment Share on other sites More sharing options...
