Mclaneinc Posted November 25, 2022 Share Posted November 25, 2022 (edited) I love my emulators, it's basically all my PC is used for but I've ran into an issue that is annoying. I was letting RyuJinx self update and it hung when replacing the files with the newer ones. The error in the background produced by it wasn't very revealing. Another time I was updating an emulator for the Gamecube and Directory Opus popped up an error saying the files was in use, yet a look at Win 10's process manager showed no direct link to the file or the main exe. Since then I've noticed that almost all the emulators that have been ran since the machine was booted would show the exact same behaviour, files used in the emulator all still in use by a process. I checked to see if a virus scan was ongoing, nope and kept looking at the process manager but as said, no in your face show of the files or the emulator being used. What is odd is that other things happily update without this issue. I made sure I was in Admin mode, I'll keep looking till I find the problem as I have to reboot every time to update the said emulators (and they have been scanned so many times for Malware or Virus, not a single instance found via Zone Alarm or MalwareBytes free. So to be clear, this only happens if one of the emulators has already been ran and closed down during the same session, if you then try to update them after this, the problem happens, rebbooting fixes it but I have a lot of emulators that update daily..A royal pain in the behind.. Any devs with any clue of this? Edited November 25, 2022 by Mclaneinc Spalling..... :) Quote Link to comment Share on other sites More sharing options...
TZJB Posted November 25, 2022 Share Posted November 25, 2022 (edited) Windows Resouce Monitor may reveal the issue. Under the Disk tab, it can show background processes with Disk Activity and you can sort the activity as required. Hope this helps. Edited November 25, 2022 by TZJB Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 25, 2022 Author Share Posted November 25, 2022 (edited) Thank you, I'll have a look.. Ah, that shows that it's suspended but won't allow a process closure....Says, denied... Edited November 25, 2022 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 25, 2022 Share Posted November 25, 2022 I know it's a pain, but I would uninstall each one, one at a time and see if you can find the culprit that way. Or just uninstall them all and re-install one at a time, run it and see again when the problem appears, you never know the uninstall/reinstall may even clear the problem Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 25, 2022 Author Share Posted November 25, 2022 I'll keep that in mind, some of these sods have a LOAD of data which I'm not keep on replacing if it's gone corrupted. Quote Link to comment Share on other sites More sharing options...
phaeron Posted November 25, 2022 Share Posted November 25, 2022 Kill werfault.exe on sight if you see it, it's the Windows Error Reporter and will commonly hold a long on EXEs as long as it's running. It's supposed to finish quickly, but frequently gets hung. Use Resource Monitor > CPU > Associated Handles > Search Handles to see if you can spot anything else holding a lock on the EXEs. Beyond that, you would need to use Process Explorer's handle search to try to find a handle to the process, as a process handle will hold the process open and thus the EXE. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 26, 2022 Author Share Posted November 26, 2022 Thanks Avery and all others.. Help noted and appreciated.. Quote Link to comment Share on other sites More sharing options...
MrMaddog Posted November 27, 2022 Share Posted November 27, 2022 I had that same problem running Project Tempest where not only it didn't end the process at exit but kept the screen on the display. Sometimes I can kill it from Task Manager but if I can't find it I use the taskill command taskkill /IM PT.exe Now if I want to run PT from a front-end, I have to use a batch file that will A.) run the ROM in the emulator and B.) kill the process after it's done. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 27, 2022 Author Share Posted November 27, 2022 Tried Killtask, said access denied, even through an Admin powershell.. Quote Link to comment Share on other sites More sharing options...
+gnusto Posted November 27, 2022 Share Posted November 27, 2022 On 11/25/2022 at 8:16 AM, Mclaneinc said: So to be clear, this only happens if one of the emulators has already been ran and closed down during the same session, if you then try to update them after this, the problem happens, rebbooting fixes it but I have a lot of emulators that update daily..A royal pain in the behind.. Does that happen with EVERY self-updating emulator? Because that starts getting into the "what the hell else is running on your system" question set. Ryujinx has a bad update approach and I've seen it fail myself more than once (I'm always careful to back it up first now). But most others use some variation of shuffle new to old without the renaming Ryujinx does, and those don't get hung up. If you have it, RPCS3 is a good check, because it so frequently updates it's almost inevitable there is one waiting for you when you launch. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 27, 2022 Author Share Posted November 27, 2022 Yuzu and Fyujinx are the worst offenders, and yes, the renaming files to old often breaks and you get a folder full of multiply renamed .old files with 2 or 3 .olds in each file name. The only reason I allow it to update itself is that some of the emulator sites compile their own release versions and muck it up a lot of times. Citra which updates nightly has no issues. I just have no clue why windows is suspending the programs in a way that needs a reboot to free them. It's not the end of the world, just annoying.. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted November 27, 2022 Share Posted November 27, 2022 1 hour ago, Mclaneinc said: I just have no clue why windows is suspending the programs in a way that needs a reboot to free them. You have to remember Windoze is a virus 🤣 1 Quote Link to comment Share on other sites More sharing options...
