Simon Carter Posted November 27, 2022 Share Posted November 27, 2022 (edited) Got a bit of an odd one. Been cleaning up some 1050 drives, and after getting one back up an running, I tested it with a Turbo Basic 1.5 floppy. Loads into Turbo Basic fine. However, after entering DOS, trying to return to BASIC using option B returns a 'No Cartridge' error, even though I've just come from there. Using DOS 2.5, and an unmodified 65XE. Pressing reset just loads up the DOS menu. Powering down and restarting loads TB straight into a TB ready prompt...as expected It's almost as if going to DOS from TB causes the computer to forget it has built in BASIC Confusticated. Any advice? Edit: Binary Loading the Autorun.sys works taking me back to TB - although at the expense of any unsaved work Si Edited November 27, 2022 by Simon Carter Quote Link to comment Share on other sites More sharing options...
Nezgar Posted November 27, 2022 Share Posted November 27, 2022 Turbo BASIC is not a cartridge (or a cartridge-like BASIC ROM in XL+ machines) - it's just a binary loaded executable, so there is in fact no cartridge present as DOS indicates. To return to Turbo BASIC you'd have to binary (L)oad the Turbo BASIC program, probably AUTORUN.SYS. Quote Link to comment Share on other sites More sharing options...
erichenneke Posted November 27, 2022 Share Posted November 27, 2022 8 minutes ago, Simon Carter said: Got a bit of an odd one. Been cleaning up some 1050 drives, and after getting one back up an running, I tested it with a Turbo Basic 1.5 floppy. Loads into Turbo Basic fine. However, after entering DOS, trying to return to BASIC using option B returns a 'No Cartridge' error, even though I've just come from there. Using DOS 2.5, and an unmodified 65XE. Pressing reset just loads up the DOS menu. Powering down and restarting loads TB straight into a TB ready prompt...as expected It's almost as if going to DOS from TB causes the computer to forget it has built in BASIC Confusticated. Any advice? Edit: Binary Loading the Autorun.sys works taking me back to TB - although at the expense of any unsaved work Si Turbo basic xl is not the same as basic from a memory address standing. The DOS command for run cartridge points to the start of the atari basic rom starting address. You can use a Run at address command from the dos menu to do the same thing with turbo basic xl, but it's a different address. I can't recall the exact address off top of head though because I haven't done that in awhile. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 27, 2022 Share Posted November 27, 2022 (edited) when you boot turbobasic internal basic is switched off, you would have a program that can twiddle the internal basic back on. Perhaps someone would throw together a basic on / basic off proggy for you. Then you could bounce in and out of whichever you wish... Internal BASIC or turbobasic. Do not forget you have other available options such as ramdisk/mem.sav etc.. I am not sure but a vaguely remember some talk of a cart version of turbobasic.. some things to explore. Using run at address might work if it's not damaged or wiped out in the process Edited November 27, 2022 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 27, 2022 Share Posted November 27, 2022 Enable MEM.SAV, and then you can return to your work from DOS with run at address -> $2080. 4 Quote Link to comment Share on other sites More sharing options...
Simon Carter Posted November 27, 2022 Author Share Posted November 27, 2022 Your answers all make perfect sense now I think about it. Just strange I've never realised it before, and I've had TB since I was 16 years old (29 years ago...) I'm guessing this is why DOS functions were implemented in TB as standard, IIRC? Anyway, thanks as always Si Quote Link to comment Share on other sites More sharing options...
erichenneke Posted November 27, 2022 Share Posted November 27, 2022 1 hour ago, flashjazzcat said: Enable MEM.SAV, and then you can return to your work from DOS with run at address -> $2080. that's it! $2080 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted November 27, 2022 Share Posted November 27, 2022 If you use the copies of TBXL at the link below, the DOS 2.5 has an altered menu item for "B." that jumps you back into TBXL. Serious Computerist: TBXL v1.5 4 2 Quote Link to comment Share on other sites More sharing options...
