Altirra - Loading tapes upon boot in fullscreen
Foebane
On the Altirra emulator for Atari 8-Bit, I can boot into it with roms, disks and other media types and they all boot in fullscreen, but when I try to boot a tape load, it opens in a window instead, even if I set the /f parameter for fullscreen. Is there a way of booting tapes in fullscreen? Some setting I can't see?
With the following command lines:
altirra c:\users\baktra\a8\pokus_changed.cas /f
altirra "C:\Users\baktra\a8\filtered\turborom_zestaw4_strona_A.wav" /f
I can confirm the behavior with Altirra 4.00; the emulator doesn't go to fullscreen
With Altirra 4.10-test26, the emulator goes to the fullscreen as expected.
So perhaps, you can switch to the development version, if you can.
Edited by baktra
  • Thanks 1
Yeah, so the backstory behind this is that loading a tape spawns a progress window in case it takes a long time, like decoding a large WAV file. Unfortunately, native Windows UI doesn't work in exclusive fullscreen mode, so this forces an exit back to windowed mode. Creating custom UI for exclusive fullscreen is a lot of work, so as a mitigation in 4.10-test I suppressed the progress dialog when exclusive fullscreen is active.
That having been said, windowed/borderless fullscreen doesn't have this issue and is recommended over exclusive fullscreen in most cases.
  • Thanks 1
